One of my quotes for a engine rebuild has the std 25 rods being shot peened and another has forged items, Being a cheap arse i like the idea of the shot peening, but whats the difference, I watched a show on TV the other day and they were shot peening std rods for a Chevy motor.
Could someone please explain as one shop says they will be fine whilst another says they wont.
Thanks. MLR
https://www.sau.com.au/forums/topic/252873-shot-peened-std-rods-v-forged-rods/
Stock Nissan rods are forged. I don't know of any Nissan engine that doesn't used forged rods, although some manufacturers have been experimenting with advanced powder met techniques.
Shot peening introduces a surface compressive residual stress which resists crack initiation and growth. If it's not done properly it can actually introduce defects.
In any event the weak point is not the rod, but the rod bolts, unless the rod has some manufacturing flaw (NDI is mandatory).
Whether you need to go to upgraded rods depends on expected power level as already suggested.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
