Hey guys,
I just gave my RB25 a freshen up. In the list of things that got done, a N1 oil pump installed. My question is directed at oil pressure. Before the install my oil pressure sat at 110kpa, which is spot on when warm. After the N1 was installed i noticed that my oil pressure is much higher - 190kpa when warm.
What are your thoughts?
Surely the oil pump has caused the pressure increase..........? is this good, bad or nothing...
what are the affects of excessive pressure and how much is too much
https://www.sau.com.au/forums/topic/252911-another-n1-oil-pump-thread/
Idle oil pressure is not so important. As long as clean oil is flowing and you have at least 5psi at idle then the engine will not fail as a result.
it is better that you have 190kpa (27.5psi) at warm idle. There is no real 'too much' amount but if I were going to say 'geez that's a bit high', it would be at around 275kpa (40psi). Pressure above 110psi can sometimes lead to issues with seals etc but normally that kind of pressure is only at cold start and/or full throttle with a shimmed high flowing pump - and even then it's only for a short period.
Make sure you have 275kpa (40psi) at around 2500-3000rpm, 410kpa(60psi) at around 4000-6000rpm.
Anything over 6000rpm, try to ensure you have at least 60psi but not so important as long as your revs stay under 7000rpm.
Also keep in mind the thickness of your oil has much more impact on oil pressure than changing the pump (n1 has pretty close to std pressure, some others like tomei are higher than those). Are you using the same oil as before?
Yeh myt oil is always old, i change every 5000kms or 3 months and before and after every track day. Im using castrol edge sport 0w-40 atm. I always use 0w-40, but im thinking i might run thicker w50/w60 at the track.
At idle its 190kpa like i mentioned, at WOT when warm, im sure i see over 600kpa. Can double check today as my gauges have recall
I just gave it a strap in 2nd on the way to get brekkie, i got 620kpa (90psi?) at 6100rpm. Thats ok isnt it? As long as itr doesnt go over 110 psi.
This is my drift car too btw.
That's good.
Anything around that or up to 110 is fine really. Even over 110 is fine but its less desirable. Your pressure is good.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
