im not 100% sure on the size of the stock rim as my gtr came with different wheels. ive got a set of 19x10 with an offset of +18. just thought some one might know off the top of their head if its legal in NSW for a 33 gtr
You are 1 inch wider already with the wheels and the track increase counts on top of that so it will be over for sure. Most cops arent going to check for track so dont worry about it but yes technically they can be defected I would say.
I have 9.5 inch wheels on mine, only 1/2 inch wider than stock but stock offset is +30, new wheels are +12 so that puts mine out also.
I have a mate who's a cop and when I showed him my wheels the first thing he asked me was what offset they were, to work out if the track was illegal.
His rim is 1" wider than stock with an offset 12mm lower (stock R33 GT-R wheels are 17x9 +30) so he's legal as long as he gets the tyres with the appropriate circumference. Just. He's on the width increase limit an 1mm below the track increase limit.
thanks guys i just couldn't work out the track with as i don't know much about off set on wheels. the tyres im grabbing are 275/30/19 with will be legal as well i think as they are 14.77mm smaller than standard tyres.
cheers guys.
I stand corrected! You are correct! He is right on the limit with a track increase of 25mm. I found this link:
http://www.1010tires.com/wheeloffsetcalculator.asp
Thanks for that, I thought my set up was illegal also. Just discovered I have 1mm spare to play with, lol. My track increase is 24mm.
I used to struggle with it as well, until someone pointed out a really simple fact to me.
The width of your wheel has absolutely nothing to do with your track. Only offset matters.
The definition of track is the distance between the centre of your left wheel and the centre of the right. That means the width is irrelevant for determining track.
Offset is the distance between the centre of the wheel barrel, and where the back of the wheel hub is (the part that you push against your brake hub when you're fitting the wheel to the car), usually measured in mm. As this then defines the centre of the wheel relative to where it attaches to your suspension, it does affect your track.
So on the same car, a higher offset reduces the track and a lower offset increases it.
So if you can only increase your track by 25mm (which is the law in every state, I believe), that means the centre of each wheel can only shift outwards by 12.5mm. That means if you have a stock +30 offset, the minimum new offset you can have is technically +17.5. Unless you've got custom made wheels, the chances are you're not going to get an offset with a decimal place so you'll have to settle for +18.
Hey dude.
The link you provided to 1010tires doesn't calculate the track increase. Only how much less room you have between the suspension, or the guard lip.
I can't find a quick definition of track for you and my laptop is about to run out of batteries. I'll post one up later.
Have a look at the RTA's Vehicle Standards Index 09 - Guilelines for alternative wheels and tyres
http://www.rta.nsw.gov.au/registration/dow.../vsi09_rev4.pdf
The wheel track is measured from centre line to centre line. It's not the outer edges or inner edges that matter.
If you fit wider wheels you will probably increase wheeltrack and this is usually associated with a change in wheel offset increasing the loads on bearings, axles, suspension joints and steering tie rods.
Emphasis added by me.
Chances are the cops won't notice. It's hard to spot visually. Chances are the sticker on the barrel is covered with brake pad dust, and unless they pop a wheel off they're not going to see what's embossed on the back of the hub.
As long as your wheels aren't sticking out of the guard, you'd have to be very unlucky to get called on it. I'd be more worried about a pod filter :)
    • Big R34 GTR parts cleanout. I have a lot of stuff collected over the last 14 years and my missus is giving me hard time. Make my life easy.   Nismo GT carbon fibre diffuser fins (discontinued)  NEW  $2900 Garage Defend Stingray canards carbon fibre  NEW  $1300  Top Secret G Force carbon fibre front diffuser  NEW  $2000  Haltech Elite 2500  NEW  $2500  Haltech Platinum Pro R34 GTR   USED  $1400  Apex’I power FC D'jetro + hand controller R34 GTR   USED  $1400  Nissan OEM BNR34 ECU  USED   $1000  HKS EVC 6  USED  $600  Blitz dual SBC ID boost controller.  USED  $350  TRE 255 LPH Fuel pump  NEW  $100  Fujitsubo  Super Ti exhaust  USED  $2700  Tomei Expreme Ti exhaust  USED  $2000  Trust stainless steel front pipe  USED  $1000  Apex’I super suction kit  USED $400  BC BR coilovers  USED  $600  Hardrace front upper camber kit. USED  $300  Garret 2860-5 turbos –  one good, one needs reco USED  $1000  Nissan OEM Toshiba MFD Screen replacement  NEW  $450  Nissan OEM BNR34 Series II front passenger seat  USED (mint) $5000   Nissan OEM BNR34 front bar in TV2  USED  $1000  Nissan OEM BNR34 front lower air spoiler  USED  $900  Nissan OEM BNR34 front lower air spoiler (painted)  USED  $900  Nismo front indicator (clear) USED  $80 Nissan OEM BNR34 radiator  USED $500  Nissan OEM BNR34 turbos  USED  $500  Nissan OEM BNR34 intercooler USED  $800  Nissan OEM BNR34 front swaybar   USED  $500  Nissan OEM BNR34 intake pipes   USED  $400    Also have a square set of uber rare Volk CE28n in 19*10 +22. Not really keen to sell these but make a high enough offer and maybe I will. If you don't know how much these usually sell for don't bother.   PM for pics.  Pickup Chadstone VIC or postage at buyer's expense.
    • Thanks Mate, I did know you could do that but i know there is a pump out there that you can bolt on and it all lines up. I was told about it and then forgot the model, I figure if i am pulling it apart i will just put a new one on
    • You can also remove the veins from the HICAS portion of your existing pump.
    • Trying to swap the rear subframe on my R34 and can't remove the L-shaped stay brackets between the front subframe mounts and the sill/chassis. I'm in the UK so rust is a problem. I've used loads of WD40 and then Tunap 103 for days beforehand. I backed off the bolts forward a bit, backward a bit repeatedly for ages to try and avoid snapping. They have all moved a few full turns. The one I've spent most time on has come loose and I can turn with fingers, and it will pull down and push up 2-3mm. But it won't come out. I can tighten it back up and loosen it off again repeatedly but it still won't come out. I assumed there's a captive nut inside but if that's broken loose then I can't understand why I can always tighten the bolt back up - I'd expect it to just spin both ways. Any ideas what's happening here? I can't visualise what's inside there to cause this.
    • Cheers, yeah it was recently imported, is the actual Nissan not an Infiniti so will have to do some chasing around for parts.    Any ideas if the side skirts from a Q50 would fit on the 400r?
