today for some reason after disconnecting and reconnecting my battery, all of the sudden my A/C no longer blows and i started hearing a clicking sound in my dash.
I'm suspecting something to do with a vent being stuck closed, maybe all the air is being relayed to the vents that blow the windows or something i dont know.
So can someone please give me some info on this?
I've read about a blend motor that can get worn down, but could it prevent air from being blown through the vents entirely?
https://www.sau.com.au/forums/topic/252925-aircon-stopped-blowing-help/
no, definately not a spark way too loud and clunky
hmmmm thanks for the fuse idea though
i took out the fuse and tried it out and nothing changed, so it could definately be the fuse.
gonna go to a parts store and have the fuse checked!
The clicking sound is either the clutch on the compressor or a relay. When you disconnected/reconnected the battery you may have accidentally earthed it out our caused an intermittent voltage spike.
If its not blowing any air at all it will be the fuse for the heater fan/blower motor assembly.
Check all the fuses in the engine bay and in the fuse box located in the dash under the steering wheel. The easiest way to test them is with a test light. Just remember to test both points on the fuse for power. If only one point lights up the fuse is blown. Also be sure to replace the fuse with the manufacturer specified amperage.
Hope this helps.
well, i checked all the fuses and relays marked as A/C and i didnt find anything,
i'm going to take a look at the blower
is there a way to test that?
oh and it's not the clutch/compressor, that's a different sound and i can still feel the compressors kick in when i turn it on as i feel my rpm's rise when it's on
dude,
you have NO IDEA how much i searched for this problem, but all that kept coming up was AC regassing problems, PBR problems and so on, nothing that sounded like what i had
but OMG i'm so hoping that this is the problem i'm having!!!!!
And i have a buddy with a wrecked skyline so it would be the perfect opportunity to get the part,
i am taking my glove box out TOMMOROW to check this out.
I'm so glad i kept bumping this thread so you replied, otherwise i would have ended up taking my dash off for nothing!
guilt-toy, you are officially my hero!
Whats your email adress? I will send you the Guilt-Toy Hero application form, if your application is successfull you can begin to pay your $50 a month membership fee and you get access to the private forums.
lol
and his private parts too hahahaha
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
