Hey guys,
Just a quick question. I've currently got the stock speakers in the car, which start to distort when i give it a bit of volume. My question is, if i got a set of these Fusion FR6520, would it be any better? Or would i have to look at getting a dedicated amp. I think my head unit is rated at 50W X 4. What are the specs on the original speakers anyway?
Thanks.
Edited by wang
https://www.sau.com.au/forums/topic/252934-65-speakers/
yeh mate those speakers should be better if anything as any good aftermarket one will be but to a certain point also assuming you have a aftermarket headunit. amp them up if you have the money and want clear, undistorted, and loud sound. otherwise if you just want them to be just abit better then stock then just screw them in and play.
https://www.sau.com.au/forums/topic/252934-65-speakers/#findComment-4373493
Awsome. Thanks mate. Would u be able to suggest an entry level amp?
Thanks.
https://www.sau.com.au/forums/topic/252934-65-speakers/#findComment-4373665
just get anything off the shelf from jb/strathfield liek jvc,sony,pioneer and so on in your price range.
otherwise response is a good amp and awesome value for money. jay car sells them if you can get to one of their shops.
Edited by jakez88
https://www.sau.com.au/forums/topic/252934-65-speakers/#findComment-4373876
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
