Nice! Those wheels look great on the M35 body, great match!
Agreed!
Stance helps ALOT though.
If you want to know about 'coolers and exhausts, check some of the other threads floating around.
Both subjects have been (and are being) covered.
In fact I think that there is a recent thread dedicated for M35 intercoolers.
Have a look or do a search.
Check with some of the sponsors *HINT* RMS Motorsport have GREAT prices and fantastic customer service. Henry makes everything very easy :)
https://www.sau.com.au/forums/topic/252986-stagea/#findComment-4374328
yer they are 19 inch rims, still undecided on how i like them on the car, i dont hate nor love the look
keen to try some R34 gtr rims
Yeah you cant go wrong with a set of R34GTR rims (not that I'm biased in any way) :)
As others have said, the rims you've currently got really do look good. Not as good a R34GTR rims though :wave: only joking.
If only the R34GTR rims came in 20" variety ....
https://www.sau.com.au/forums/topic/252986-stagea/#findComment-4375923
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
