hey, well on thursday my turbo decide to make some very unusally howling sounds..
it makes it wen acclerating and wen decelerating aswel..
anywyas i wasnt that far from home..
so anyways..
i took the turbo off..notice i had about 2mm shaft play..not that much..and both comp. and exhuast wheel was fine...but spun the wheel and notice some very loud bearing noise from spinning it..so i just thought my turbo bearing was gone...
so anyways i got a s/h turbo off a series1 r33..
but i put my actuator on..
this turbo had about a 1mm of shaft play and had NO bearing noise sound wen being spun..
and i used his oil feed line..instead of mine..just incase i had a blockage in the line...
and i put on oil feed/return lines back on..and water feed and return lines back on..
wit no leaks...
i got just water inside..since im flushing the old coolant out aswel..
anyways...after the secnd-hand turbo was just fitted prefectly..
all hoses and bolts on tight and seemed all good...
i turned the car on..
but notice a very faint sound or whinning/howling sound again...
and yes...its the same sound as before..but not as loud...
but i assume it would get louder if i hit boost or got high in the revs...
i just dont wana risk it...
any ideas???
and i do got a full level of oil and water in the rad.
a mate is tell me to change the wastegate..to the one that came with the turbo..
could this be the problem??
i dont know if its the same sound but i had a noise that sounded like a bearing in the turbo, sounded like it came from the turbo anyways.
turned out to be timing belt bearings were gone, replaced them and sound disappeared.
Could be wrong but it would explain why changing the turbo didnt fix the sound...
well, i cant exactly pin-poin the sound..sounds like it coming from the turbo, then it moves up or out the afm then pod..
but then i thought it was power-steering pump..or air-con pump..well there pulleys..
but yeah..cant exactly find wer its coming from...lol
but can the wastegate actuator cause this fault? not opening, then causing turbo to whine??
ok..well ive fitted a series1 turbo on my car yesterday...
and it had like 1mm shaft-play and NO bearing sound wen i spun the wheel..
so this turbo got fitted...
i started the car but still had the whinning sound...
so anyways..one of mates said try a different wastegate actuator..
still no good as sound was still there..
ive even checked the compressor wheel again...just make sure there isnt dmage to the wheel or bearing sounds...
but looked and sounded perfect!!
so its no that again..lol
but what im thinking now..it could b water-pump..or some idler pulley???
im pulling the front cover off 2day..
neva takin if off before...or either a timing belt...
but my timing belt was done lik 16,000 k's ago...
but i didnt change the water pump or either idler pulleys...
so i'll check here next...
could normal drive-belts whine, as the way ive described my first post?
Edited by bumble_bee
I dont want this to sound like a ''it's this, because it happened to me'' but ;) my sisters R32 had the same noise and i thought it was turbo bearings. Turned out it was the idler bearings as the outer bearing race had come apart, got stuck around the timing belt and made it jump a few teeth on the inlet cam! Lucky there was no valve on piston love.
get a big screw driver flat head and put the tip on differnt parts of the engine and the other end n ya ear you will hear the vibrations of where its coming from
oh ok..but was ANYONES SOUND during acceleration or wen back off the throttle?? could U hear it whining down aswel...???plus theres no whining on idle....
im thinking its an idler pulley...
there are 2 idler pulleys on a rb25det..is that correct??
but im taking the top timing cover off today..so ill have a look...
and from wat i can see..theres no leaks on the intercoolering piping..
hey "lowRB" wat did ur whining sound like?? wat is during idle or during acceleration/de-acceleration?
could b air-con pulley..sound from that side of the engine...
mit take that belt off..and see if she does it...is that u found out it was the air-con pulley??
Yeah mine would go up and down with revs as pulley went faster etc, made hardly any noise on idle only tiny bit, yeh ended up pulling belt off and could hardly spin the pulley was nearly siezed up.
ok, i had another look..
its definatly from the turbo again..
how could i get the same sound from another turbo?
i thought that my line was blocked...so i took off the oil feed bolt on the turbo(17mm) and ckecked to see if oil was going to the turbo..
looks lik it was getting oil..i evan marked the bolt so the hole was facing the line..so that oil would flow through...
should oil pore out/piss out wen taking this bol off??
coz it doesnt..
but yeah...i took it round the block...which is like 500m..
sound is still there..and i notice burning oil/smoke coming from the back of the turbo...just wen i got back...seems to drive fine..but sound is still there...
i believe it was the oil/crap on the back off the turbo..wer the exhaust wheel and wastegate flap was..
i believe it was burning all that residue/crap off..
does that sound rit???
i also have one bolt thats not in place..becoz the guy who took it off snap the bolt..and try to drill out but f%c#ked it..so i to leave it not bolt in the op corner.....im using my old manifold/turbo and dump seals aswel...
the guy said the turbo was his for about 2weeks...so could it be just running in??
Could it be just a clamp hold loose on a coupling?
Check all your silicone couplings and clamps.
I had that whinning sound before.
It sounded very much like a average size twin ball bearing turbo but louder. It sounded like spool came much faster.
doesnt sound like intercollering piping...
its definatly coming from the turbo area/intake sideof the engine..
i took off my pod filter..and put my ear next to it and u could hear it louder,,,
mit b the stock flex-rubber pipe from afm to compressor...
could have a split in it...
Have you tried removing your air con belt to rule that pulley out?
I would start there... takes 5 seconds, then move on to the next thing
what he said
happend to me, my belt was on too tight. loosened it off and the noise stopped
well, i got new turbo and dump pipe gaskets today..i just got gen. nissan ones..pretty cheap so yeah..
techs from work reckon its a gasket leak..but they wana have a look...
so i'll post up wat they reckon...
has anyone else had a similar whining sound from the turbo area?
wat would a gasket leak sound like anyways? would it sound like wat ive described??
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
