hey, well on thursday my turbo decide to make some very unusally howling sounds..
it makes it wen acclerating and wen decelerating aswel..
anywyas i wasnt that far from home..
so anyways..
i took the turbo off..notice i had about 2mm shaft play..not that much..and both comp. and exhuast wheel was fine...but spun the wheel and notice some very loud bearing noise from spinning it..so i just thought my turbo bearing was gone...
so anyways i got a s/h turbo off a series1 r33..
but i put my actuator on..
this turbo had about a 1mm of shaft play and had NO bearing noise sound wen being spun..
and i used his oil feed line..instead of mine..just incase i had a blockage in the line...
and i put on oil feed/return lines back on..and water feed and return lines back on..
wit no leaks...
i got just water inside..since im flushing the old coolant out aswel..
anyways...after the secnd-hand turbo was just fitted prefectly..
all hoses and bolts on tight and seemed all good...
i turned the car on..
but notice a very faint sound or whinning/howling sound again...
and yes...its the same sound as before..but not as loud...
but i assume it would get louder if i hit boost or got high in the revs...
i just dont wana risk it...
any ideas???
and i do got a full level of oil and water in the rad.
a mate is tell me to change the wastegate..to the one that came with the turbo..
could this be the problem??
i dont know if its the same sound but i had a noise that sounded like a bearing in the turbo, sounded like it came from the turbo anyways.
turned out to be timing belt bearings were gone, replaced them and sound disappeared.
Could be wrong but it would explain why changing the turbo didnt fix the sound...
well, i cant exactly pin-poin the sound..sounds like it coming from the turbo, then it moves up or out the afm then pod..
but then i thought it was power-steering pump..or air-con pump..well there pulleys..
but yeah..cant exactly find wer its coming from...lol
but can the wastegate actuator cause this fault? not opening, then causing turbo to whine??
ok..well ive fitted a series1 turbo on my car yesterday...
and it had like 1mm shaft-play and NO bearing sound wen i spun the wheel..
so this turbo got fitted...
i started the car but still had the whinning sound...
so anyways..one of mates said try a different wastegate actuator..
still no good as sound was still there..
ive even checked the compressor wheel again...just make sure there isnt dmage to the wheel or bearing sounds...
but looked and sounded perfect!!
so its no that again..lol
but what im thinking now..it could b water-pump..or some idler pulley???
im pulling the front cover off 2day..
neva takin if off before...or either a timing belt...
but my timing belt was done lik 16,000 k's ago...
but i didnt change the water pump or either idler pulleys...
so i'll check here next...
could normal drive-belts whine, as the way ive described my first post?
Edited by bumble_bee
I dont want this to sound like a ''it's this, because it happened to me'' but ;) my sisters R32 had the same noise and i thought it was turbo bearings. Turned out it was the idler bearings as the outer bearing race had come apart, got stuck around the timing belt and made it jump a few teeth on the inlet cam! Lucky there was no valve on piston love.
get a big screw driver flat head and put the tip on differnt parts of the engine and the other end n ya ear you will hear the vibrations of where its coming from
oh ok..but was ANYONES SOUND during acceleration or wen back off the throttle?? could U hear it whining down aswel...???plus theres no whining on idle....
im thinking its an idler pulley...
there are 2 idler pulleys on a rb25det..is that correct??
but im taking the top timing cover off today..so ill have a look...
and from wat i can see..theres no leaks on the intercoolering piping..
hey "lowRB" wat did ur whining sound like?? wat is during idle or during acceleration/de-acceleration?
could b air-con pulley..sound from that side of the engine...
mit take that belt off..and see if she does it...is that u found out it was the air-con pulley??
Yeah mine would go up and down with revs as pulley went faster etc, made hardly any noise on idle only tiny bit, yeh ended up pulling belt off and could hardly spin the pulley was nearly siezed up.
ok, i had another look..
its definatly from the turbo again..
how could i get the same sound from another turbo?
i thought that my line was blocked...so i took off the oil feed bolt on the turbo(17mm) and ckecked to see if oil was going to the turbo..
looks lik it was getting oil..i evan marked the bolt so the hole was facing the line..so that oil would flow through...
should oil pore out/piss out wen taking this bol off??
coz it doesnt..
but yeah...i took it round the block...which is like 500m..
sound is still there..and i notice burning oil/smoke coming from the back of the turbo...just wen i got back...seems to drive fine..but sound is still there...
i believe it was the oil/crap on the back off the turbo..wer the exhaust wheel and wastegate flap was..
i believe it was burning all that residue/crap off..
does that sound rit???
i also have one bolt thats not in place..becoz the guy who took it off snap the bolt..and try to drill out but f%c#ked it..so i to leave it not bolt in the op corner.....im using my old manifold/turbo and dump seals aswel...
the guy said the turbo was his for about 2weeks...so could it be just running in??
Could it be just a clamp hold loose on a coupling?
Check all your silicone couplings and clamps.
I had that whinning sound before.
It sounded very much like a average size twin ball bearing turbo but louder. It sounded like spool came much faster.
doesnt sound like intercollering piping...
its definatly coming from the turbo area/intake sideof the engine..
i took off my pod filter..and put my ear next to it and u could hear it louder,,,
mit b the stock flex-rubber pipe from afm to compressor...
could have a split in it...
Have you tried removing your air con belt to rule that pulley out?
I would start there... takes 5 seconds, then move on to the next thing
what he said
happend to me, my belt was on too tight. loosened it off and the noise stopped
well, i got new turbo and dump pipe gaskets today..i just got gen. nissan ones..pretty cheap so yeah..
techs from work reckon its a gasket leak..but they wana have a look...
so i'll post up wat they reckon...
has anyone else had a similar whining sound from the turbo area?
wat would a gasket leak sound like anyways? would it sound like wat ive described??
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
