Hey guys.
wrecking this 180sx. Located in Brisbane. parts and prices will be listed. if its not on the list just pm me.
thanks
Turbo Kit: includes Garrett 2540, thickwalled custom manifold(will never crack), External Gate, Screamer pipe, braided lines, Dump front pipe, hotpipe(if swapped with original hot pipe. $1900ono
Genuine Volk Te37's Silver with chrome lip. just been resprayed good tread. $2000 ono 5 stud off my other car. 9" front 9.5" rear! good offset
Ecu: Microtec lx8 - $450 inc loom
Microtec hand controller - SOLD
JIC fully adjustable coilovers - $800
Front mount kit- $250
Adj castor rods - $130
Crome 18in rims(as pictured) - $400
Diff - $150
Clutch Master - $80
Clutch Slave -$25
Reo bar - $130
Engine cross member - $140ono
Catback Exhaust $150
Pedal box - SOLD
Brake master and booster $80ono
Complied 180sx shell with windows $1200
headlights - SOLD
Rear fiberglass bar - $50
Front fiberglass bar - SOLD
brakes and rotors - $180
sway bar - $40
seats - $50 ea
Carpet - $40
Roof lining - $35
Dash(has crack) - $70
sr20 gearbox with ca18 cross member (2nd gear syncro gone, still works though) - $100
550cc Injectors - $450
walbro fuel pump - $80
fuel tank(good nick) $150ono
lots more parts inc interior
thanks guys
ph: 0423 849 355
Edited by sly32
https://www.sau.com.au/forums/topic/253028-wrecking-180sx/
  • 6 months later...
  • 3 weeks later...
  • 8 months later...
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
