Hi all
Does anyone know wether the RB25 engines have problems with the oil pumps and or oil pump drive. I've read that the rb26 engines can have problems in that area.
Thanks for any info
yes they do
  • 9 months later...
Early R32 GTRs had a small oil drive on the crank and needed crank collars, late R32 GTR's (94s did, not sure when 93's started getting it) got the same crank as the R33 GTR (with the bigger oil drive and no longer needed collars)
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
