Must sell $20,000 as is. No trades, sorry.
I have several cars and its time for this completed project to go. This car owes me almost $90,000 in total.
This a true 300-350RWKW car with heaps or torque and very low engine km. Don’t be fooled, there are no cheap, crappy parts; no short cuts and no money spared on this project. Just looking for a quick sale.
This car will do 0-100 in approx 3sec and 1/4 mile in under 12sec every day on 98 octane.
If you are interested call me on 0414 575 676 or send me an e-mail at [email protected]
If I don't respond to your e-mail it is because I think you are wasting both my and your time.
VEHICLE SPECS:
This is a R33 Nissan Skyline GTS-t sedan with $60 000 in modifications.
The vehicle is in show condition and has never been raced; has done less
then 5000km in the last 3.5 years. Engine has less then 30,000km; modifications in general all have less
then 5,000km. Every modified component on this vehicle is from a reputable OEM (99% from Japan); no inferior parts.
The vehicle has passed a full QLD Department of Transport inspection and is ADR compliant, and comes with all necessary paperwork.
The vehicle is currently registered and is located in Brisbane - Southside.
Engine Modifications:
Large Trust front mount intercooler
Front mount oil cooler
Relocated oil filter kit
Trust Blow-Off valve
Performance braided hoses (Pirtec)
Greddy intake plenum
Nismo 850cc injectors
High volume Walbro fuel pump
Apexi variable fuel regulator
HKS 264 cams (exhaust and intake)
HKS exhaust cam gear
Nismo de-compression plate
VG30 Airflow meter
Cold Air pod and polished enclosure
Trust high mount exhaust
3.5 inch Japanese Nismo exhaust
Garrett ball bearing GT35R turbo
Turbosmart external 58mm waste gate
Cusco brake booster
Earthing leads
Voltage stabiliser
Custom detailing (pearl, chrome and polished)
Apexi AVCR boost controller
Apexi SAFC
Apexi Power FC and Apexi commander
Splitfire coil packs
Large polished aluminium radiator
GTR water pump pulley
Three auxiliary electric thermo fans
ADR approved polished catch can
R34 GTS-t Block with R33 Head (less then 30 000km)
All belts replaced (Timing etc)
Driveline Modifications:
Locked 4.3:1 differential (std is 4.11:1)
Solid differential cradles
C’s Short shift kit
HiCas Lock bar
OsGiken Twin Plate Clutch
Suspension and Brakes:
Tanabe coil overs (adjustable)
GTR N1 rear sway bar
Front and rear strut braces
Caster rods
Wheels:
235 and 255 /55/17 Advan Racing wheels
Exterior Modifications:
Full body kit
Custom Impul front bar
Custom rear wing
Series 2 tail lights
Window tinting
Interior Modifications:
Black leather front race seats (ADR approved and Blue plated)
Black leather customized rear seat
Black leather custom rear parcel shelf
Black leather door inserts
Black leather gear shifter boot and handbrake boot (Issota)
Black roof lining
Black 2 pac gloss series 2 dash
Blitz Temp gauges - Exhaust
Blitz Temp gauges - Oil
Blitz Temp gauges - Water
Nismo dash gauge pod
Chrome door handles
Black Leather Nismo sports steering wheel
Audio Modifications:
JBL DVD,CD,Tuner,MP3 - 6channel, head unit
6.5 inch KIT6.5 front splits
6.5 inch Alpine splits (rear)
2 x Orion 10 inch dual voice coil Subs
1.2 Farad Capacitor
Alpine 4x100 RMS Amplifier
Audison monoblock 900 RMS amplifier
7 inch rear TV screen
Custom leather finished sub enclosures
Custom leather finished boot
Custom leather finished rear parcel shelf with enclosed speaker boxes
C.A.M three point alarm (Insurance approved)
Please contact me via mob:0414 575 676 or at [email protected]
Thank you
https://www.sau.com.au/forums/topic/253031-highly-modified-r33-gts-t-350rwkw/
Anodised ally nuts used on number plates. Each hand drilled to fit stainless allan key bolt. Each one (set) will set you back about $5. There are about 100 in the engine bay. Adds up quickly.
All about doing the job right.
weekly bump.
Guys, this car is scheduled to be stripped back to stock in two weeks.
I really don't want to undo the huge amount of work done on this car, it would be a real shame. BUT it needs to go as I have tooooo many toys.
For only a couple of extra bucks then a stock R33 you get a low km engine with EVERYTHING, nearly $60,000 spent on modifications. Car owes me almost $90,000 but must go, nowhere to keep it.
PS. If not sold, ALL parts will be available for sale in three weeks. May or may not be posted here so contact me if you are interested in anything specific.
T - 0414 575 676
PM sent.
Extra info:
Car is currently registered, can supply RWC for QLD buyer.
Chassis has about 175,000km.
Engine bought from Japan with 25,000km.
All mods and parts changed are less then 5,000km.
if/when you part out i may be interested in the following;
-Turbosmart external 58mm waste gate
-Greddy intake plenum
-Apexi Power FC and Apexi commander
and possibly the top mount manifold that you used.
please pm me with prices or contact as i will forget to check here.
MUST SELL - this toy must go or it gets stripped back to stock on the 6-8 Feb 09.
This week only $18,500 as is. First to make deposit gets this toy. You can't build this car for less then $35,000 and owes me almost $90,000.
Must go, call me on 0414 575 676.
  • 1 month later...
    • Interesting.  Great info. thank you.  Give a few days to get that name plate.  I have a busy life most weeks.  I will be in touch.
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
