Hi all..
I have a Silvia S13 with RB25det, fully forged internals and loads of other mods, just waiting for bigger turbo and aftermarket computer... this is where you come in? Hopefully? I am looking at either a GT2871R or GT35R (depending on money factor) and have been recommended various computers for this. Now if I had the money, it would be no question I would get a motec, but as it is the funds are tight and Im thinking of either an Apexi Power FC or (as numerous people have recommended) a Wolf... So here's the question... which is better or any other suggestions??? Thanks in advance ;)
https://www.sau.com.au/forums/topic/253054-chasing-advice-engine-management/
Choice of ECU has been covered plenty of times, try searching.
Usually its best to decide on a tuner and ask them :wave:
Power FC is very common on skylines tuning on 98 octane fuel...it works with great results. If your using E85 or something then you need to re-consider a lot of things :)
I don't think anyone out there uses regular unleaded on these engines do they??? Always run 98 otherwise you're asking for serious trouble.
Run a Vi-PEC far superior than both the ECU's you mentioned....see Guilt-Toy's thread about his...he used to be a Power FC man through and through...now he has a Vi-PEC he will never go back to an old technology Apexi unit.
They are just as good as a MoTeC without the massive pricetag.
Fantastic, thank you HEAPS I'll certainly check out that thread... other options are always welcome, thanks heaps for the suggestion :D
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
