Hi all,
Im building a 25/30 (N/A until im off restrictions), therefore going for a high comp setup, hence using RB25DE pistons. .
Just wondering if it is necessary to buy new rings for the pistons when I put them in the 30 block, and if not, is it necessary to hone the cylinder walls. .
If I need to get new rings, are the RB25DET and RB25DE rings the same?? And also what brand should I be looking at. . I looked at OEM Nissan and they wanted 500 just for rings. . Seems a bit expensive to me?
Thanks,
Josh
https://www.sau.com.au/forums/topic/253077-rb25-piston-rings/
How long are you on restrictions for?
If its not long, dont waste your time/$/effort. Unless you absolutely MUST have an NA Skyline.
Buy a Honda. Factory reliability, decent power and alot of cheap aftermarket bits to play with.
The motor isnt going into a skyline. . Im a vl boy lol :wave:
Im on the restrictions for another 2 years. . Ive spent a lot of money on this motor already (I am going to keep the bulk of it when I am on my opens for my new motor), I just need a set of RB25DE pistons to bump up the compression for now. .
So yeah. . What rings and from where? And is it necessary or can I just put the pistons straight in?? (with the rings on them of course)
Edited by ...Joshwa
