google is your friend...
Bosch 910, 200 l/hr @ 5 bar (73.5psi), supports 220 rwkw (15mm in, M12 x 1.5 out)
Bosch 975, 228 l/hr @ 5 bar (73.5psi), supports 250 rwkw (15mm in, M12 x 1.5 out)
Bosch 984, 228 l/hr @ 5 bar (73.5psi), supports 250 rwkw (12mm in, M12 x 1.5 out)
Bosch 040, 235 l/hr @ 5 bar (73.5psi), supports 260 rwkw (in-tank pump with screen & M12 x 1.5 out)
Bosch 044, 330 l/hr @ 5 bar (73.5psi), supports 360 rwkw (14mm in, M12 x 1.5 out)
  • 2 months later...
odds r the hose clamp screw was rotated around in the "wrong" spot - if there is one
thats where mine are and it went straight in
I had mine installed for ages and got surging at half a tank. Thanks for the pic worked straight away and pump sat right Cheers
  • 1 month later...
Just finished installing my 040. Damm that stupid air tight top cover. Bitch to take off and refit. Never want to do it again. Luckly I check for a click noise when i slid the cradle on. With my HKS exhaust. I can't even hear the pump wine. I like the wining noise it makes like external pumps. Going for a test drive now.
  • 1 month later...
I used this tutorial to fit my walbro, pretty much the same procedure. The walbros are a fair bit smaller (width wise). I didn't cut the bottom c shaped bit off, instead used it to hold the bottom of the pump and wedged a steel nut between the bracket and pump then used the hose clamps to secure it.
Make sure you double check the o ring is sitting in place correctly before tightening the big plastic ring, silicon spray on the thread helps big time!
Cheers for the right up OP
the wiring didnt look too bad when i changed mine out and I just used the crimps that came with the kit, but jaycar sell "chemical resistant" heat shrink.
http://www.jaycar.com.au/productView.asp?ID=WH5526
Hmm I seem to have into run into the issue of the pump not wanting to go into the fuel tank also. I have taken 2 photos for reference.
First up I am guessing everyone has this white thing (fuel level sensor?) or do they have something different?
And 2ndly is everyones space this tight? There seems absolutely no way to get the pump past the point in this picture. I have it mounted the same as in the tutorial possibly marginally lower but would be nearly negligible.
I am installing this in a series 2 r34 so unsure if there are differences or not gonna go back out there and keep trying maybe try lifting pump higher.
Alright got it in and it works so I guess the only advice I have to give is don't give up cause its not hard getting the bracket into the holder it's a lot harder to get the actual pump down where you need it. I am not sure how I got it but with a bunch of wiggling and my arm all the way down feeling to guide the pump it went in.
Definitetly a pain now I just hope nothing goes wrong that I have to check it again
Pulled my cradle with walbro out of my s1 and swapped with stock pump with cash my way with guy at work with s2.
Mounted 040 as per photos on here. Spent 2 hours adjusting twisting etc and I can garuantee it won't go in with hose clamps attached. Wedges into tank and sits 50-60mm from bottom. Not sure if s1/s2 brackets are different but don't think so.
Ended up extending hose 10mm from standard and put it in without clamps. Its wedges in hard between tank and bracket and is firmly held. Can barely squeeze a finger under it and is lower than walbro with sock.
Hey guys, just for reference, the post above IS correct in terms of the 044... My car ran 360.7kw and the pump was pretty much on its limit... It is in the tank and is dead quiet (a big surprise to me) and i couldnt be happier! For those running an R34 the fuel pressure gets a bit sketchy at that HP but there is a modification that can sort it out, the boys at JEM sorted mine out and safely ran it back to 357rwkw which is the final tune :yes:
I was a bit worried about fitting an 044 to my car for daily use, but now that its in and ive driven it i strongly recommend them :)
I seem to have an issue with fuel pressure loss when car sits for a while.
Do people usually install a 1 way valve to help hold pressure? Apparently the stock pumps have a 1 way valve built in? I will have to double check my fuel filter as I changed that but can almost guarantee there is no leak there
Hmm I seem to have into run into the issue of the pump not wanting to go into the fuel tank also. I have taken 2 photos for reference. First up I am guessing everyone has this white thing (fuel level sensor?) or do they have something different? img1218fx.jpg And 2ndly is everyones space this tight? There seems absolutely no way to get the pump past the point in this picture. I have it mounted the same as in the tutorial possibly marginally lower but would be nearly negligible. img1216wu.jpg
What I did to get around this problem was cut the brack and fit the pump right up top. I then annealed some copper pipe so that it was nice and soft ( about 400mm of it) flared 1 end of it with a tube flaring tool. using a Jic fitting on the bottom of the pump I then bent the tube by hand so that the fuel pickup is bassicly on the very bottom of the tank and about 150mm towards the front of the car.
The gain is that you can run the car almost dry before it will get fuel surge, the problem is that I don't run a fuel filter before the pump.
Regards
Chris
Regards
Chris
That sounds like a good idea. I am able to drive my car on the light for a while with the pump installed how it is but it scares me so won't let it ever get as low as I use to (when i was lazy about getting fuel or tight on money)
Try dropping it in without clamps like I did. It's locks up right at the bottom and mine was solid as a rock and 10mm from thd bottom
I tried for a good couple hours before removing clamps. Not sure if it was because I put a s2 bracket in my s1 but I doubt it. When I could get it in clamped about 50mm from bottom was as low as I could get it
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
    • Is the toolbox that damaged the boot seal the same item that fell on the car during the storm a while back?
    • Who are you to deny yourself? I’ve said this many times to myself and apart from getting what I really want, I go quiet for a while whilst working out what I just did to my savings and how will I afford what it cost, then, next payday…
