Enkie circular 17 inch wheels
They are 17 by 9's all round +22 offset front and rear
One has some paint faded on the face but all the polished parts of the rims is good condition with minimal gutter rash.
Selling as they dont fit over brakes I have.
TIRES NOT INCLUDED BUT AVAILABLE SEPARATE.
Asking $800 for the four
Tein HA adjustable coilovers. Removed from the car due to an upgrade.
Perfect condition no leaks or damage.
Inspections welcome asking $800.
Apexi pod filters with cast alloy adaptors. Filters in good condition with some wear marks at the points where they touch each other. Other wise clean and no damage.
Asking $200.
Cusco upper control arms for R32 GTR. Shorter than factory and give around -3 degrees camber. Not adjustable just shorter. Bushes in good condition arms appear to okay as well.
Asking $200.
Genuine Nissan R32 GTR bonnet. Gunmetal grey in colour, Good condition no damage other then light marks in the paint that would polish out.
Asking $450
R32 GTR boot lid with wing.
Perfect white paint pannel is imaculate all over
Asking $300
Full set of super advan wheels. They are those three spoke red and black wheels. Have a set of Advan A048 tires with another track day or two left in them
17 by 9's +22 all round
One rim has some damage around the face where it was wacked but its still round and does its job.
Asking $450 with the tires.
Everything is located in Sydney and I can send smaller items but larger ones will require you to organise your own freight.
May be negotiable on some things as its no use to me anymore.
https://www.sau.com.au/forums/topic/253103-loads-of-gtr-parts/
I know this may be a dumb question, but does the GTR boot lid fit the GTS-4/ GTS-T boot? The guards don't seem to widen until below the boot line, so I gotta ask. My boot is looking rusty (literally) so it may be time to swap it out.
R32 GTR and GTS-T boot lids are interchangable as the shape of the boot opening is identical - my son is running a GTR boot lid on his GTS.
Re: the Teins;
- do you know if the height adjusters move ok
- what's the spring rate (let me know the dimensions and I can work it out if you dont know)
And: are you in Sydney?
Yes all the height adjusters move perfectly fine. None of them are seized. Same as the dampner adjustors they all in perfect working order
current spring rates are 9 front 8 rear. I do have a few various springs around that I may be able to switch around depending what your after..
Yes Im located in Sydney.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
