Gidday,
the front end decides to shake like hell where and when it wants to.
Under braking, it intensifies if up at a decent speed such as 60km/h or more.
It started to happen after I replaced the front shockers in the struts.
I've checked the shockers are tight in the strut case, the springs are mounted right, the brakes are tightly bolted up against the struts again, the strut bottoms mounted tightly, the sway bar is mounted correctly and the leading arms bolted up correctly.
All I've changed is the tyre pressures up to 32 psi, and the shockers to Pedders.
Could it be the alignment is out because I've had the complete package apart?
Could it be the tyres causing the shimmying [shaking]?
Edited by kools
need to get the steering box gears roconditioned
i have had it done before
if your in qld i know a person who can do this
Sorry, I don't understand your reasoning there, as the steering box feels good the rest of the time. It steers well, has only a minor leak, and if I didn't already make it clear, the steering wheel shimmy's with the wheels when they do it.
I'm in Wheelers Hill Melb.
Thanks for your idea though, but any other ideas/suggestions? :P
kools
Are you ABSOLUTELY sure all the bolts are done up correctly? You are certain that the strut was sitting down properly on the lower control arm before you tightened the bolts?
I'd be checking every possible place in the front suspension for a couple of loose bolts.
mine did real bad at 1 point, still kinda does randomly but i put it down to the box and bukled wheels.
wat i found was my:
tyres were stuffed
ajnd the rims wernt locating on the hub
new tyres and hub locaters cars sweet, well better..
  • 1 year later...
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
