hai guyz
i got a baby sulpher crested cocky up for sale
its pretty much those white ones you see
his hand raised so loves people and is a bottomless pit..
should be ready in about 4-6 weeks.. all weaned
on seed + veg.
itl still beg and stuff so a feed of egg and buscuit formula every now and then wont hurt..
i want $500neg for this little mofo..
pm me for detailz
pics up tomorrow
https://www.sau.com.au/forums/topic/253135-cockatoo-baby-cockatoo/
Hi Adz
these dont need a license
a cage thats about 1000 x 1000 should be enough if you intend on getting it out etc...
the one advertised it already learning how to climb out of its box and is now getting used to cage life.
playing with them everyday will be good to so they can bond with you. these things have the intelegance of a 3 yr old
oh man,.. why must you be on the wrong side of oz ? i been searching for one of these babies here in QLD.. but im always 1 day too late..!
i would be very keen if you could find someone who are willing to freight them to Brissy.. im pretty sure some freight company does it.
here you go mate.
bit hard to get the pics as they just want to scramble all over you
they are NOT imprinted so they know their little birds, not little humans as some people get all lovey dovey.
so this one can handle being alone if you need to go out.
their cracking seed now and should be ready in a couple of weeks.
hey have you tried putting an ad in petlink.com.au?
these birds need socialising at least hold and play with them everyday to avoid them biting and bored. Needs a lot of chewing toys as well.
They can be freighted, look up in yellow pages there are freight companies that are specialised on sending pets or birds. They just need a travelling cage, plenty of food and water. Either the company will pick it up at your place or drop it off at the airport, then the buyer picks it up.
but my advice is get a local buyer less stress for the poor bird.
Goodluck!
rocky has be sold guys!
his going up to geraldton!
i know of the stresses of freight
but toos are tuff lil things and hold up well.
you have birds too?>
I've got 2 eclectus, smart birds but needs a lot of attention
just like raising kids
need fresh fruit & vegies
toys so they wont get bored otherwise they'll pluck their feathers
they are a bundle of joy though
great pets
Edited by Rob_C110GTR
    • Ha! well, there's your problem!Β  Guess the last person in there didn't have great attention to detail....
    • It seems like you guys want to behave like rabid dogs, rather than gentlemen... Knowing one has jumped in on a fellow comrades near done deal, and sniped it at the last second, how can one sleep at night?
    • My wifes says we have a spare set.
    • Good news!!! Changed the O ring today and I’ve got the β€œpssshhhh” back when I open the fuel cap πŸ˜‚πŸ™ŒπŸΌπŸ™ŒπŸΌ It was 100% the O ring because that bloody thing was inside the fuel tank πŸ˜‚πŸ˜‚πŸ˜‚πŸ˜‚πŸ˜‚ Fitting new fuel pump was a pain as always since the DW is a bit longer than stock. But she’s running!!! ❀️
    • PWM quite literally just chops the ful 12V voltage on and off at whatever duty cycle you're running it at. If you're running it 100%, then it is on full voltage all the time, same as if there was no PWM. If you run it at 50% duty cycle, it is only seeing the full 12V half of the time. This is broadly equivalent to running it at 6V. But the crucial difference is that motors (and a lot of other loads) don't like being powered at low volts. They will either fail to start rotating, or draw a shit ton of current, or other undesirable things. But if you give them the full volt, and then a short period of no volts, and then some more full volts, then the times when they are seeing power they are seeing all the voltage, and they are happy. But you get the performance out of them as if they were only seeing that fraction of the full voltage. It is not really easy to answer your question about what flow you will get out of it at 50% duty cycle. I can tell you that it is not as simple as you think. For a start, that 460 L/h pump is not going to flow 460 when you're on boost. When you're on boost you will be somewhere down the sloping part of that red line. If you have 15 psi of boost, then the pump can only deliver about 95 gal/h, which is <380L/h. So your simple 50% on 460 = 230 wasn't going to work anyway. But also, it won't deliver 50% of 380 either, because when you devolt or PWM trim th epower being fed to the pump, it is not able to deliver flow or pressure in the same way. 50% duty cycle will probably produce <50% of the full voltage flow. The way to find out what duty cycle you need to run it at at low load (ie, at idle) is to idle it and turn the DC down until you start to lose fuel pressure, then turn it back up above that with some extra for safety. And then you do the same thing at full load, in case it doesn't need anywhere near 100% DC. And if you're careful/caution/prudent, you will also do it at a couple of loads in between so you can shape the DC map against load. It might not be linear between the two end points.
Γ—
Γ—
