yeh i wouldnt listen to someone who said its the oils fault they lost 3kw when they dyno'd their car on different days lol, can anyone who doesnt like motul give me a real reason, I use penrite anyway im just curious to know why people dont like motul for a good reason
nah thats cool, i dint mean that my xr6 t guy was biblical lol, could be right, could be wrong, but every car is different, everyone drives them different, even depends on your altitude of where you dyno the car. the kw gain/loss thing isnt important at only 3kw, but he recons the oil temp with royal purple was on average 75degrees but similar temps, similar driving same fuel his temps would hang around 85 degrees.
to compare with my own experience when my elf is new i average about 70degrees and now when its starting to burn it runs at 80-85degrees and has lost a noticeable amount of power (not dynoed, just from feel of the car).
best is to try differnet oils and keep a close eye to engine temps and work out for yourself which is better for you. Lower engine temp means better cooling by radiator, slightly cooler air getting into the turbo (reduce risk of detination, heat saturation, better more complete burn of fuel) increase the life of the coil packs..... less friction.... all this means better economy, safer more reliable car to run.... common sence really. but use what you feel is good for YOUR car. then pick what is a good price for what you get.
ive used both motul and elf very recently, and I cant feel any difference, nor see any temp difference...
So what weights were the Royal Purple VS Motul? Which Motul oil was he comparing - 4100, 8100, 300V?
Even things like differences in humidity will see a 3kw difference from one day to the next!
We change the oil so often in these cars that it would never get the chance to go off - except for burning it at track days etc. I dont think the brand of oil makes much difference at all. as long its fully synth you're not going to see a noticable difference if you're comparing oils with the same weight.
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
