ok so recently ive been to autobarn caz one of my headlights are out, they said my 32 is a H4 according to their lil book
ive had experiences with them recommending the wrong type of headlight globe before and not accepting a return
anyways, i need to change my low beam and i cant seem to take the globes out. it seems to be factory light globes and havent been removed before
theres lik a lil metal clip on top of it. do i just grip it and rip it out?? anyone changed their headlights on 32 gtst's before?
also im prob lookin at gettin those bright blue globes. good, bad?
plz help
https://www.sau.com.au/forums/topic/253171-removing-headlights-from-r32/
i changed mine not to long ago, i should of done both at the same time.. now i have one brighter than the other.
push the spring clip down and tweak it up.. you shouldn't need to rip that clip out as u need it there to hold the globe
There is a clip that runs around the globe housing inside of the lens, 1 of them when pushed in slightly & will unclip- unlocks the globe and allows it to pull out, its really fiddly to do, if you have a missus with small hands she may be able to do it otherwise just bear with it, sooner or later you will unclip it and the globe comes out really easy, its another story to get the little blighter back in but after undoing it you will know how it works
bright blue projectors look like arse as well.. ;)
i know what you meant, but taken this way I like it more. yes, non-projectors are usually h4, and projectors are h3c. usually..
Edited by heller44
    • PULSAR PSR2860R 0.86A/R or 0.64 GEN 2 Turbocharger Both are -50*67mm 8 blade billet compressor wheel Cheers
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe.....EDIT... nope, the Kraken is a cast jobbie, the REv9 uses welded up stainless, plus $8000 AUD before shipping, installation and tuning) Where else in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit that Pulse fitted, and it was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
