As title says I'm new to the skyline world. The forums are great, haven't spend this much time reading since...can't remember when.
Anyway, I'm about to become the owner of a nice R33 SII GTST. I'm looking at getting a fmic, looking around the forums the TMU boys seem to be
cracking down on chopping the body up for the intercooler piping. I know you can get en eng cert, but i'd rather not stuff around.
So what are my options? I see that justjap have a 'stealth' intercooler, where the pipes return to the same side. Tho there are some tight bends in it,
more lag?. But there is also a dual outlet core as well? I've done a few search's around the place and can't find out much about 'dual outlet' cores. What is
the performance difference etc? I think the dual outlet on justjap is 3" and the standard piping is 2.5"? so 3" to 2.5" silicon hose will do?
I dunno?
https://www.sau.com.au/forums/topic/253176-im-new-fmic-and-the-tmu/
i'd go the stealth cooler if you wanted to keep the car legal but if you chuck on a pod as well it defeats the purpose of having a stealth cooler and get ready to be defected once pulled over.
the JJR stealth series intercooler is a wise choice...I don't beleive there is any tight bends (the only bend I can see is from the cooler itself (thus making it a turnflow) and shouldn't be any lag. but as jake said if you do get a pod filter, you just be defected as you can only have one intake mod BUT if you want to be sneaky about it get a cold airbox assembly like the they on Just Jap have for sale so then you have a pod but it's also sealed so all you're getting is cool air running into it
Interesting Signature you got there BigDirtyJase.
Go for the stealth intercooler setup and get it intalled professionaly and if you wanna upgrade the intake, just put a high flow panel filter. APexi, K&N filters, any.
yep stealth is the way to go !
oh wait think i remeber somthing about air bags ? if you car dont have them wont be to hard to pass it. but TMU wont care and defect you anyway.
i got a twin entry one. but too many people getting done for it, end of feb it should be off and up for sale and replaced for the stealth. so much stuffing around,
get it done right the first time !
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
