Chucked a Turbo into my 1994 R33 GTS-T RB25DE.
Whenever I hit the boost at like 0.5bar for more than a second, the whole car jumps and the turbo drops out to -0.5
One friend said I need a new Fuel Pump that can handle the Turbo as the RB25DE Fuel Pump isn't giving it enough fuel.
Another friend says it's my Fuel Compression Ratio, what should my ratio be and how should I check it?
Any ideas?
(Spark Plugs and Coil Packs are fine)
What ECU are you running?
I'm not sure what ECU I'm running, I'm not as knowledgable as I probably should be about engines.
It wasn't actually me that installed the turbo, it was the previous owner, I'm not sure what modifications he made to it after putting in the turbo.
If it were me I'd be starting ground up.
Get a list of everything you know is in the car.
Then get a list of things you dont know about i.e. ECU etc etc
It will be easier to get help if you know whats what - as opposed to guessing.
But I would be taking it to your mechanic as it doesnt sound fuel related more electronics.
My 2 cents...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
