Respray
Guest CleanAndSimple
First off ill apolagise for starting a new thread. :D
Recently been getting ever so more and more pissed off with bad blends here and there, and thinking about getting a respray.
questions are what price am i looking at?
thinking either full respray (body, engine, boot, cabin etc)
or
like shut door, considering im doing the same colour.
thoughts?
any idears on price?
and where does a good job?
https://www.sau.com.au/forums/topic/253273-respray/
  • Replies 65
If you are as picky as me, I'd be budgeting atleast around $8000 for a full respray. Means all windows come out, all new seals etc. Some good workshops around... All Type Crash I've heard good things about, I use and SWEAR by All Make Crash.
Had a very bad experience with one of the "big" workshops here in SA, I won't name them but I definately wasn't impressed with their workmanship.
End of the day, it all comes down to how deep your wallet is and just what you consider a "good job"
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377429
How much money u got to spend?
Would u wanna sand back the car yourself?
resprays can range from 3k to 12k
My recommendation is Edwardstown custom body repairs if u got the money to spend. Or if u wanna sand it all back yourself my mate who works there might be able to do a cashy on the side.
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377427
yeah 3k wont get you much these days, as with an old car like a 33 things are usually perished or very fragile when you remove them, and tend to break.
Even materials along cost abit, sand paper, prepsol, primer,paint,clear, nuts/bolts everything has to be taken into account.
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377436
Like Luke said, for 3k you won't get much... My saying is, if you are gonna do it, you might as well do it properly. Imagine how pissed you'd be spending 3k only to get a finish you aren't happy with?
Money down the drain isn't it, and back to square one
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377442
do you really need a respray or a really good detail? I'd be willing to give it a go cheap if the paint isnt destroyed already? save you a bunch of money, I redid mine after I priced the respray...lol and I'm picky ..lol
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377516
old car?33? lol your car's only 2 years younger than mine. hehe bite your tongue
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377654
Although I haven't had any experience with them Tom Howard did a good job of colour matching the orange/gold pearl when Flick got the fibreglass guards painted.
Tom Howard did a good job colour matching part of the underbody with my side panels ;)
and All Type Crash... I'm not too keen on going back there.
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4377705
i wanna get my dato done but im fearing the figure theyll throw after seeing the rust n bog areas :blink:
anyone know a apprentience painter that needs a practice car? i dont really care if the dato's not perfect aslong as it doesnt fall apart from rust :P
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4378038
This is from another thread, im to lazy to re-write it :blink:
If you are after a full respray its gana cost you around 8-10k. If you take out the motor and interior and prep that in 2pac primer it will be around 5k. If your good with a spray gun i would paint the engine bay,cabin and door jams in the colour you want and that will be around 2-3k to finish the job. If your good with body work i would take it further and prep the outside in 2pac primer and that will be around 1k to paint the outside.
these are prices from some of Adelaide best places
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4378133
Don't think he does powdercoating ... not that I was aware he had the equipment.
Looked at that link, the map is slightly incorrect. His 'shed' is at the right hand bend of Chapman Road on the left ... furthest shed in the corner of the lot. There is a chroming specialist next door to him. One stop shop :P
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4378665
he powdercoats rims too doesn't he Ruby?
http://www.yellowpages.com.au/bi/daniel-st...sa-5608307.html
No he doesn't, but he does a good job of painting them, im very happy with the way my rims turned out :laugh:
https://www.sau.com.au/forums/topic/253273-respray/#findComment-4379995
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
