Respray
  • Replies 65
i work at a crash repairer and i can tell you it is not cheap. would be cheaper staying the same colour than changing the colour. doing the engine bay will add alot more money to the job too.
so how many slabs of beer will it take to have you respray the nose of my car, just touch up stuff and a ding , I dont have the gear here to do a proper job or the clean area to do it.lol
you should never mention skills, maybe would could trade skills if you need anything done..?
https://www.sau.com.au/forums/topic/253273-respray/page/2/#findComment-4387598
Car Cosmetics at Lonsdale they are awsome and very well priced ...
Im going to say it and i dont care if it gets taken down or what ever.
That dude is shit, plain and simple. He done my GTR, had some rust where the rear right mudflap screws to the body. I told him i wanted it cut out and sprayed as i will keep the car for a while, and i had to go through regency (for an unrelated defect but i dont want dodgy shit) I got it back and was just full of fiber fill, topped off with bog and painted. I confronted him about it and he didnt want to have a bar of it and said i told him to fiber fill it, haha ok what ever.
I ended up going to extensive restorations at lonsdale, they cut the inner and outer skin out and made new ones and welded it in, much better. Cost the same amount as bringing to BOGmetics too.
If you want someone skilled in the art of bog sculpting go to car cosmetics, i think its all he knows.
Edited by GTR1993
https://www.sau.com.au/forums/topic/253273-respray/page/2/#findComment-4390091
To save making another thread.....anyone got a rough idea on how much it will cost to get the holes in the front guards for the side indicators covered (Preferably metal as they are standard guards)?
Best to just take them to a local welding shop and ask them if they will do a cashy. it shouldn't take them long to do, should only cost an hour or two of labour. Then just give them to paint shop and they will be able to bog them up and smooth them out.
https://www.sau.com.au/forums/topic/253273-respray/page/2/#findComment-4391671
Performance Spray Painting & Crash on stanbel rd, salisbury plains.
They just did my HR31, new roof skin, closed doors respray but colour change, some old front damage fixed, welded up holes in boot and where antenna was, rust cut out behind tail light = $5200 (including remove + replace all windows and seals)
I used to work there and only ever saw top quality work in that place. The owner, George is a gun spray painter with some of the best blending/colour matching skills ive ever seen. And doesnt charge through the asshole.
Has sprayed plenty of old classics and show cars too
https://www.sau.com.au/forums/topic/253273-respray/page/2/#findComment-4391726
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
