Model: MY06 STI
Registration Number: GIVE WAI
Contact: <Wai Yang>
Email: <waiyan at iinet dot net dot au>
Phone: <0402629376>
http://www.carsales.com.au/pls/cars...icle_id=6686182
MY06 STi without rear spolier
400HP atw with easy pontential for 700hp without much more work.
Spent close to $120K
Cosworth engine done about 6K (2k were running in w/ no boost)
Chasis has done 29,989km
looking to sell to buy new car.
PM interest. no ridiculous offers.
$80,000
Cosworth Cylinder Heads:
• CNC Ported - New Castings
• Hand blended finish work
• Intake – 21% Increased Flow (average)
• Exhaust – 42% Increased Flow (average)
• 4-angle Inlet Valve job
• 3-angle & radiused Exhaust Valve job
• Valves are lapped
• Back-Cut Inlet Valves
• Heads are Ultra Sonic cleaned prior to assembly
• 1mm Stainless Steel Intake Valves (1800 degrees max.)
• 1mm Inconel Exhaust Valves (2400 degrees max.)
• Performance Valve Springs
• Titanium Retainers
• Hardened Steel Spring Platforms
• Cosworth Billet Camshafts
• Cosworth Head Gaskets
Short Block:
• Custom Machined to a closed deck
• Darton Ductile Iron Flange Sleeved
• Cosworth Forged Pistons
• Cosworth Forged Con-rods
• Cosworth Billet CrankShaft
• Cosworth Bearings
• Cosworth Piston rings
• ARP Head studs
• JUN Oil Pump
• Garrett GT3540r
• Tial 44mm wastegate with screamer
• Greddy Race BOV
• GT spec headers
• Custom Up/Dump pipe
• Catless Exhaust
• K&N POD Filter
• Perrin Front Intercooler
• Cutom Turbo mount/ piping
• Perrin Oil Catch Can
Electronics and Fuel System:
• MOTEC M800 Goldbox, Rotational, Antilag, adv. Functions and Launch Control
• AIM MXL Sports Dash
• Defi Boost, EGT, Oil Pressure
• Apexi Turbo timer
• Alpine 310e DVD player
• 2 x 265l/ph fuel pump
• 800cc Powerenterprise Injectors
• Perrin Fuel Rails
• Aeromotive 1000hp Fuel Pressure Regulator
Driveline Hardware:
• Exedy Twin Carbon Plate Clutch
Rolling Stock, Brakes and Suspension:
• D2 Street Coilovers
• Whiteline front and rear sway bars
• Whiteline front and rear strut brace
• Whiteline Antilift Kit
• Brembo 8 pistons custom mounted
• Slotted disks
Misc.Hardware:
• Perrin Crank pulley
• Perrin Radiator shroud
• Perrin Radiator hoses
• XTR Turbo Bag
• Cobb Short Shifter
• Ignited Engine Start
Exterior:
• Chargespeed side skirts
• Chargespeed Back lip
__________________
https://www.sau.com.au/forums/topic/253292-fs-my06-sti-give-wai/
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
