yeh pretty much as the title says, having a huge coolant leak from the back of the engine but havent been able to pinpoint where from.
had the car up an put copious amounts of fluid through the radiator and it pisses out the back and from what i can see it gushes out above the gearbox, but there is jus sfa room to have a look where its coming from? ;) any one else similar problem?
i've searched not only this but a few other forums but havent been able to get an answer. jus hoping i could get some sort of an idea before i take it in to a mechanic
cheers for any help
https://www.sau.com.au/forums/topic/253295-r33-s2-leaking-coolant/
water pump leaking? that tends to be sign of "change me"
hoses to the firewall leaking? ( passenger side)
The drain plug on the engine blow which is on the passenger side leaking?
cant think of much else which could be contributing to a radiator leak at the back of the engine..
Edited by br3ndan
heater hoses
but more than likely the turbo water feed from the back of the plenum.
thats what i was thinking but hoping it wasnt..
thanks for all the help guys will try get some time after work and have a look and take some photos
ok had another look after work today but started to piss down so didnt get much time but its not pump, not the hoses to the firewall im pretty sure its either the heater hoses or the water feed but cant quiet see, pretty sure i've got it pin pointed at the bottom right hand side of the block as u look at it head on.
Taso84 what did you end up having to do with yours?
thanks for any help
this is an absolute broad minded person of a job but you have to do it man
when i did it, it was on my mates s12 w/sr20 conversion and there is NO ROOM at the back
we had to remove the plenum to properly access the hoses
here is a tip: if your struggling undo the gearbox mount and jack the gearbox up higher, it will slope the engine downwards and give you a bit more room to work
here is a pic of the hose i had to replace
sh*t from what i've read this will be aprick of a job or a hit to the back pocket. yeh tell me bout the lack of room its crazy!
yeh i figured i'd be taking some stuff off/out, thanks for the help gfunkk.
jus gunna grab a mate or two and a case an see how we go this weekend i reckon.
cheers for the help fellas
bottom right of an RB - only water above that are heater hoses and the steel turbo feed line.
Or a welsh plug in the block...
go to a mechs and see if they can pressurise your coolant system to allow you to check it exactly.. then see if you want to fix yourself or not
