yeh pretty much as the title says, having a huge coolant leak from the back of the engine but havent been able to pinpoint where from.
had the car up an put copious amounts of fluid through the radiator and it pisses out the back and from what i can see it gushes out above the gearbox, but there is jus sfa room to have a look where its coming from? ;) any one else similar problem?
i've searched not only this but a few other forums but havent been able to get an answer. jus hoping i could get some sort of an idea before i take it in to a mechanic
cheers for any help
https://www.sau.com.au/forums/topic/253295-r33-s2-leaking-coolant/
water pump leaking? that tends to be sign of "change me"
hoses to the firewall leaking? ( passenger side)
The drain plug on the engine blow which is on the passenger side leaking?
cant think of much else which could be contributing to a radiator leak at the back of the engine..
Edited by br3ndan
heater hoses
but more than likely the turbo water feed from the back of the plenum.
thats what i was thinking but hoping it wasnt..
thanks for all the help guys will try get some time after work and have a look and take some photos
ok had another look after work today but started to piss down so didnt get much time but its not pump, not the hoses to the firewall im pretty sure its either the heater hoses or the water feed but cant quiet see, pretty sure i've got it pin pointed at the bottom right hand side of the block as u look at it head on.
Taso84 what did you end up having to do with yours?
thanks for any help
this is an absolute broad minded person of a job but you have to do it man
when i did it, it was on my mates s12 w/sr20 conversion and there is NO ROOM at the back
we had to remove the plenum to properly access the hoses
here is a tip: if your struggling undo the gearbox mount and jack the gearbox up higher, it will slope the engine downwards and give you a bit more room to work
here is a pic of the hose i had to replace
sh*t from what i've read this will be aprick of a job or a hit to the back pocket. yeh tell me bout the lack of room its crazy!
yeh i figured i'd be taking some stuff off/out, thanks for the help gfunkk.
jus gunna grab a mate or two and a case an see how we go this weekend i reckon.
cheers for the help fellas
bottom right of an RB - only water above that are heater hoses and the steel turbo feed line.
Or a welsh plug in the block...
go to a mechs and see if they can pressurise your coolant system to allow you to check it exactly.. then see if you want to fix yourself or not
    • No idea about the remote start part. If the V37 nav is anything like other Nissan JDM vehicles, you can't get the factory Japanese nav working in australia, a card from a different car almost certainly won't work, those cards are usually matched to the serial number of the DCU.  You could be possibly swap out the components from a AuDM Q50 to get it working, but if this is a new model (2021+) 400R, then you will lose the newer features like ACP/AA.  That said, if you have ACP/AA, just use google maps.. I assume a band expander would be required to get the local radio stations, but don't forget the Japanese FM band is narrower than ours, so you still might not be able to receive all Australian stations. I can't see any reason the tyre pressure sensors won't work here, there is the sensor unit inside the rim and the receiver nearby in the wheel well.  I have never had to change the batteries on my 2015 Q50, so I assume they last quite a while.  A straight battery change shouldn't need them to be re-registered as they are the same unit, that should only be required if you replace a sensor with a new one.   Word of warning, if you ever go into the 'secret' diagnostics mode on the main screen, DO NOT EVER do a 'reset' in this menu, it will erase all of your model specific data in the DCU and you will need a trip to a dealer to re-program it all, which would be particularly painful being an import.  This applies to the AuDM Q50 too.
    • There is a known issue with the mix door motor on the Q50 which causes these symptoms, not sure if it is common on the Y51 though.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
