Organised Street Racing ?!
craig R33
 Share
  • Replies 117
Posted Images
Probably some thugs asking that much so they can get you down there and mug you.
pretty simple if you think about it.
Cops surely wouldnt do this.
Street sick racers wouldnt ask so much. ,
would think if they wanted to bait hoons would they be realistic with a $200 entry fee to win $2k
yeah, but they probably think hoons (and by extension thanks to association, us) are all cashed up drunken wankers.
cops can and do lure people this way, very common in USA....good luck not ending up in jail..lol
I did find a new makeshift drag strip near me, while new white lines painted the right distance a part, and lots of burn out marks, I would never race on it, very wavey road in the sticks..... end up in the ditch for sure.. but it explains the noises i heard sat night at 4am,, damn commy hoons and a bit of WRX noises, maybe a SR20 too
Edited by sapphiregraphics
This has happened before.
See: http://www.nissansilvia.com/forums/index.p...84&hl=drift
Except this one isn't really drift, more race...
Looks like they're putting the drift ones on Silvias and Race ones on Skylines ;)
Most likely SAPOL. Ring the number. If you get a location, rock up in a Lancer or something...
except nobody worked out who it was on NS..............................
so we have no idea who is behind it
I like the rocking up in the lancer idea
nah they want hoons that actually have cash, no point impounding a car that no one would pay to get back.
no but it would get the hoons off the roads. and word of mouth will bring out the racers for cash. so its a double win for sapol.
and get defectable cars in one spot. you would be suprised how well it works in USA... and not classified as entrapment either..lol
some of the cashed up hoons also sell drugs for cash, so they get hit too.. sapol wins either way
anyone google the number yet ? or do a reverse lookup? online you can find out about anyone brian spilnar, so they say in 2f 2f..lol
2k a bit rich, how bout the damage done to your ride when the bogan v8 slams into you cause he's losing
paul walker for sure, is ludachris running this 1? its gonna be another all timer tonight :blink:
Edited by Inline 6
 Share
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
