I had pretty much come to the conclusion that the australian stig was just one of the 2 presenters with racing experience. They surely don't have the budget to employ another whole person for something they are both capable of.
The racing experience of the presenters is very limited...
Cox did some racing in the UK and V8 Bathurst here with average results
Pizzati has done a couple of vic state formula ford races in 1999 with back of the field results.
http://www.natsoft.com.au/cgi-bin/results....8/1999.VSRS.E25
http://www.natsoft.com.au/cgi-bin/results....8/1999.VSRS.E13
http://www.natsoft.com.au/cgi-bin/results....4/1999.SAND.E32
I think it's you Kev... ...I sure saw enough evidence around your place to point to it... :)
For the UK version there are a few stigs atm, Depending on the car. Some companys want there own driver to drive the cars and some dont care.
1st Stig Perry McCarthy former F1 test driver (one they shot of a ship)
2nd & current Stig Ben Collins has raced Indy, IRL F3
USA Stig Mario Andretti
Heiki Kovalevien drove the F1 on the TG Track
The Australian Stig is TURN AWAY NOW IF YOU DON'T WANT TO KNOW..........
The Bates Brothers
1st it was though to be Russel Ingal but was later found out to be both the bothers
Edited by nvsA4
I refuse to believe it...
I might believe it is the American Stig... ...That dude sure had the physique of a NASCAR driver...
Lol
Exactly... just don't click on the link, and keep the dream alive!!! :P
Oh and some say that the he lives on my TV.....
That's awesome! Wish I had him on my dashboard.
The Bates Brothers
I cant tell you it is NOT the Bates brothers, Neil Bates has a rock solid contract with Toyota, runs the largest rally team in Australia and certainly doesn't have the time to hang around a film set for days at a time.
Now Rick Bates on the other hand....
Lol
It's easy to do.... although not with the black helmet lens. (thats the hardest part i've found to find)
The Target store @ Malvern has $4.95 Lego kits of this...
http://cgi.ebay.com.au/LEGO-Mars-Mission-5...%3A1|240%3A1318
Then just borrow your GF's nail file and sand off the print on the torso. :D
Failing that, just have a son who's massive keen for Lego and just collect it. :)
Failing that, just have a son who's massive keen for Lego and just collect it. :P
Cool. Must try that. Thanks.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
