I need to disconnect the actuator pipe to run open boost .. I dont have a boost controller yet so apparently this is a good way to see how the car will behave if I did have one installed..
Only thing that controls the boost at the moment is the wastegate spring.. can anyone point me to the right pipe / hose to disconnect to achieve this? Thanks in advance
engine bay pics are as follows:
https://www.sau.com.au/forums/topic/253359-wheres-my-actuator-pipe/
Find the actuator and pull the vac hose off it? There is only one...
And is the car "stock"? AS it wont behave much at all once it hits boost cut, or the turbo explodes
Edited by gotRICE?
http://www.skylinesaustralia.com/forums/Rb...&start=220#
Its got a few mods, and yeah ill be watching the boost like a hawk.. I dont produce full boost until around 4k, so this test could be interesting to try out
whats the actuator look like? hence why i posted the pics .. cheers
Edited by Vanilla_Rice
had me confused as hell here sorry, so basically since the external wastegate does what the actuator used to do I'd be right in saying yank that hose of that since the stock actuator / turbo setup is long gone
It will probably BLOW UP judging by the amount oil coming out of you rocker cover vapour hoses
yeah thanks for noticing but its not like I'm gonna be driving it around everywhere like this, I doubt ill go over 3k its just to see if the boost will build quicker since my lag is shocking
just took the hose off and went for a drive, made stuff all difference car is still laggy as hell.. was at about 14psi at 3800ish rpm .. so im highly doubting a new boost controller will make it any better.
I was really hoping to produce my 19 pounds (current spring setup) at a lot lower revs with this td05 but hey, im not really sure what to expect running open boost like that.
Yeah made a bad call. For some reason i overlooked the external :)
I suppose i should mention that its a knock off chinese td05, probably explains a few things.. Although from my experience this turbo produced more hp than a genuine mitsi turbo on my last dyno run @ same boost but they generally dont last as long.
ummm removing the VAC line to an actuator wont do anything (if you still had one)
You need to wire the gate/actuator shut if you want to test if the turbo gate is opening prematurely causing poor response (if you still had one)
And i say - "if you still had one" because fk me...
You have an EXTERNAL WASTEGATE - you do not have an actuator... The gate is the actuator.
So no idea what anyone in this thread has been talking about... look @ the fluro poofter pink thing in the pictures!!!
So... as before - removing the hose, same in this instance, isnt going to do a thing.
If you want to test the GATE spring being the cause, just take the gate off and put a blanking plate on it, you'll soon see if its gate creep causing the problem or not
And get rid of that silly filter thats blowing oil over your engine bay. I kid you not when i say this... that filter will give you a fire in your engine bay when it spits oil when things are hot. I've seen 3 cars catch fire because of those retarded filters that server no purpose other than getting an insurance payout for a burnout car.
Oh, btw - insurance wont payout because that's your own fault for a illegal, and dumb mod :(
Oh, btw - insurance wont payout because that's your own fault for a illegal, and dumb mod :ermm:
wow thanks, kinda.. :thumbsup:
Just so were clear, this is New Zealand .. and its perfectly legal..
I didnt even install the filter thing, it magically appeared after mechanic installed the turbo, if its a stupid mod fine, but I just left it on cos i assumed it did something. Im not a mechanic!!, hence why I use this place to obtain answers, so enough with the flameing.. purple poofter thing??? come on, does it need to be black or something.
but thanks, for your insightful answer I do appreciate it..
btw - the oil all over the place is from a crack in one of those pipes, yes it needs replacing..
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
