Hi guys,
I have had a wierd noise in/on/around my RB25DEt for a while but never got around to do anything with it so 1st off ill explain.
Sepc (if it matters)
1998 R33 GTS25t
59,000km
Stock dump > 3" HKS Front > Decat > HKS Hi-Power Silent Catback
R32 10psi Actuator with stock solenoid removed
Apexi Panel filter
Blitz LM FMIC
This noise only EVER occurs at cold idle. And when i say cold, i mean the block has to have no heat in it at all. So its generally an overnight thing. The next time its started it does it.
It does not ever do it once there is a bit of heat in the engine. So to overcome it i generally let the car warm up for a few mins or so before i drive it. Other than this. Everything sounds/runs mint.
Engine runs strong, never misses a beat. Runs great on the track and drag strip.
And when on a long run, apart from the exhaust you would swear it isnt even idling (when stopped) it is so quiet. Sounds amazing.
So heres the noise. Can anyone identify it? Is it "normal"? Does anyone else have the noise?
The noise is clearly obvious. And it does it anywhere from 1200rpm > 1500rpm. Anything more/less its not there.
A friend of mine on this forum, his RB25DEt also does this, but it is very quiet. Still noticeable, but compared to his mine is like a megaphone is attatched to it.
Can anyone recommend anything?
Thanks in advance for the help. As the noise does bother me.
Edited by gotRICE?
https://www.sau.com.au/forums/topic/253375-sau-lend-me-your-ears-rb25-noise/
Timing belt
Timing belt bearings
Water pump
Alternator bearing
VCT camshaft pulley dry
Could be any of these things and more. When was the last time the timing belt was done? and if it was supposedly done before you bought it, just say NFI.
hmmmmmmm.. sounds a bit like piston slap (piston slapping against the side of the bore while cold) but that shouldnt happen in a standard internals engine.. could be something at the little end of the rod... it doesnt sound quite like big end knock.
Timing belt
Water pump
Alternator bearing
NFI, but i would imagine it hasnt been done since i bought it at 48,000km 1st owner in NZ.
I guess it could have done a million KM from Japan, but the overall appearance of the interior/exterior/seats/underbody would suggest its fairly genuine.
Only way to figure what one it could be would be by changing each one i guess... And does this mean that these problems could become less apparent when they are warm?
if its internal and as the car gets warm it goes away it would lead me to believe its to do with the cams and oil, i dont think its internals though, internals normally make a bigger sound,
as for mentioned about about the water pump and alternator etc... i think these are on the right line, one way to check, take the belt of alternator and start the car, if there is no sound, its either you water pump or alternator, try those different things
not block noise Dan ?
Yeah, you are right Gervaise.
I had another listen to it and it does seem like a forged piston rattle. Nothing serious if it's forged pistons inside but I would definitely be making sure you have it running for at least 2 mins before you drive it from cold.
You heard mine aye Bevan? Makes a noise of sorts though I think mine is quieter, was it the same thing? Mine has been doing its noise since I can remember (I remember panicking about it in 2005 when I noticed it from the outside of the car) but 4 years, >60,000km and 100kw on its still fine lol.
Edited by Lithium
Thanks guys
I will give the alternator trick a go and see what happens next time its cold cold.
Then i will think about doing the waterpump/cam belt etc..
I use Motul Turbolite oil. Seems to do the trick. But have recently sourced Royal Purple for a pretty good price so might switch to that next.
I wouldnt know if its forged but i highly doubt it as i bought the car stock standard. So hope its not piston slap!
And yup, was yours Dan my man. I mentioned it when we did the coilpacks. :laugh: Will give these things a try.
mate i personally think it sounds like lifters/tappets. the fact that it goes away once u rev it past 1500rpm and also goes away once the motor is warm would suggest to me its lifters/tappets. try using a thicker oil on ur next oil change annd it should hopefully do the trick :laugh:
mate i personally think it sounds like lifters/tappets. the fact that it goes away once u rev it past 1500rpm and also goes away once the motor is warm would suggest to me its lifters/tappets. try using a thicker oil on ur next oil change annd it should hopefully do the trick :(
Yeah still a bit deeper in pitch than a lifter noise. Usually lifters are a higher pitched tapping noise. You could be right though, it's so hard to tell these things when all you have is a youtube video. I hope is something simple. It's never nice when you find gremlins in your car. :(
  • 11 months later...
Im still stumped.
Noise is still there at the same interval, Cold start, around 1500rpm. And still stops as soon as it starts to warm.
Car still makes fantastic power, and is regularly tracked/drag raced. Drives perfectly...
Switched to Royal Purple Oil/filter's last change and no effect.
Still have my stock pile of waterpump/belts/ tensioners etc. Just havnt got around to getting it done yet ha. Fingers crossed its still one of these.
If not... i guess one day it will go boom.
Mine has done it for a good 70,000kms so far - maybe more... I lose track. I am pretty sure I first noticed it in 2005. Since then its seen track time, god knows how many drag runs (a good number of which reasonably into the 12s) , dyno runs, street driving, compression tests (with good results), 3 different turbos, up to 20psi of boost, a new cam belt and it seems no louder than it was when I first noticed it.
I have no idea what it is, but am pretty sure that if it was bearing noise or a damaged piston skirt I'd have known about it by now!
    • 65601-05U00 is the hood latch. 62550-08U31 is the support that holds it to the radiator core support. They are all super discontinued so I don't really have any great leads on how to source this stuff.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
