Hey Guys,
Got a few things for sale:
WORK Emotion Cr Kai's
17x9 +17 in Gunmetal Grey
One rim has slight gutter rash on it and most of the rims have some paint chipping but still look tuff.
$1650
PICS HERE: http://www.skylinesaustralia.com/forums/post-a186708-
R32 Carbon Fibre Stereo Surround
I purchased this off Sniper Racing as part of a beta testing program, ive done majority of the work to get it to fit but its still a little off just cant be bothered and im sure somone else has the skills to get it to fit.
$50
Stock HCR32 Rear Swaybar
Not much to say about this good condition not bent or anything ive just upgraded.
$20
HCR32 Passenger Side Indicator
Pretty average condition the top clip has a bit snapped off but you can still hold it in with a scre and its cheap so buy it!
$20
BLiTZ Single DIN 3 Gauge Holder
Who wants some JDM?
$50
Willing to post everything except the swaybar.
Located in Southeast Suburbs Melbourne.
Contact Via PM or email - [email protected]
:laugh:
Kyle
guys i just want to make it clear for those who cantr ead the two lines above the price of the carbon surround, IT DOESNT QUITE FIT, IT WILL REQUIRE MODIFICATION TO FIT PERFECT IVE DONE MOST OF THE WORK JUST NEEDS A LITTLE BIT MORE, hence the cheap price, now first in with a pm now gets it, thanks
would you post wheels to qld?
how much
i would prefer to sell locally at the moment but if i cant move them here i will consider interstate
plenty of offers on the wheels unfortunately a bit too low at the moment
  • 4 weeks later...
    • Looking at finally painting and installing my R32 GTR wing I bought back in 2018. I got two quotes: Quote 1: $880 includes: wing, spare boot, holes welded up prep/paint. Pro: full boot with wing AND hole-less boot with lip i can swap between Con: $$  Quote 2: $330 wing only. Pro: cheaper Con: lose my (relatively) rare no holes sedan boot Also to consider I do plan on painting my whole car at some point "soon" (been saying that since 2018) Anyway Enjoy these All Japan Day 2025 pictures of my 4 door, still rocking the Calsonic Livery! Rolling in Interior shot Matching Peer Pressure Racing overalls are pretty cute ngl. This year was a hard 1990 cut so I got to be over with all the older cool stuff Next to arguably the best car there. A mighty S-Cargo
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
