xd9s are 18x9 +20 with 215/40 direzza dz101s. 5x114.3 and are in very good condish. PAIR ONLY!!!!!!!!!!!! $900
bride brix 1.5? good condish apart from a couple of small tears. im talking smaller than a 5c peice. with bride rail to suit r32 $400
GTR cusco castor rods. dont really know what there worth? $170?
dmax Dtail to suit s13 BUT i did try it on my 32 and its very very close to fitting nicely. very small amount of mods required but ide like a buyer to try it on just incase. $200 its brand new.
RB26dett power FC its sweet no issues comes with hand controller. $700?
let me know if you think prices are too high...
i also have 4 GTR injectors. cleaned and flow tested $200
rb20 afm $50
t28 turbs bush bearing only 80,000ks old. $350
ok thats it cheers
0401178091
https://www.sau.com.au/forums/topic/253420-parts-work-cusco-bride-etc-etc/
yeh adelaide sorry i knew ide forget something. yes i have another 4 xd9s in 18x10 but unless you got some serious cash you aint getting them. looks like power fc is sold.... ide like to move the wheels people there are fricken cheap! and yeh im 80kgs and fit perfect. not super super tight. its "street tight"
Anyone here know this seller (Adam) ? I paid for the Power FC of him last week but yet to receive it. Called him a couple of days ago and he said he already sent it that day. When asked for the tracking number he said he had it at home and would call me back with it. This call was at 9am Syd time meaning 8:30am in SA so if he just sent it through the post office he would have to have done it at that time and have the receipt with him.
Since then I have yet to get a reply to my sms, pm's or calls answered. Wanting to know if anyone bought anything of him and if you have received it as yet?
Obviously if you are thinking of buying off him be cautious.
This may be nothing, but i'm getting a bad feeling that I will get ripped off in this deal.
Adam if you are reading this could you please contact me ASAP.
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
