so i go looking at the timeslips on SAU..... WTF...... not one stagea in top 20....... theres even a frickin magna there running 14.8 ! c'mon guys surely there's a stagea out there quicker than the magna !?
thats it.
I will be going to willowbank soon. test n tune probably 4th feb now, and should come back with a magna beating time.... if you stagea owners have any pride you will do the same :) <---- thats a joke, but i mean it :laugh:
Jez
https://www.sau.com.au/forums/topic/253430-timeslips/
tomei's do a 2.8L stroker for the 25 i beleive... i'm not 100% sure, but 26 crank/rods/pistons fit in a 25 block, so i imagine they would all work.. however you are much better off starting with a 26 (as most people do, thus the lack of stroked 25's)
and brad's is stock... JUN 2.7L stroker with T04Z from factory :(
https://www.sau.com.au/forums/topic/253430-timeslips/#findComment-4380368
yer as mentioned its a rb26 with 2.7L jun kit and hks t04z, 18psi is very low boost for the setup, the motor is in another car now and will be tested to its full potential very soon if i get off my arse and finish it :)
The new setup is rather disapointing for me (slow) but its all legal and engineer approval is 99% sorted and it will become my daily driver. Its now got a new engine combo, rb26 head, rb30 bottom end, gt3076r, stock gtr 5 speed, etc, im thinking a gt35 is on the cards because it needs more power to push the heavy thing along.
https://www.sau.com.au/forums/topic/253430-timeslips/#findComment-4382399
yer as mentioned its a rb26 with 2.7L jun kit and hks t04z, 18psi is very low boost for the setup, the motor is in another car now and will be tested to its full potential very soon if i get off my arse and finish it :P
That's exactly my dilemma, although I'll be staying with2.6l capacity: GT35 seems to be the way to go - my little N1s are struggling to really get the car moving like I want it to...
https://www.sau.com.au/forums/topic/253430-timeslips/#findComment-4382588
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
