I am pretty sure nothing needs to be changed, you may need lower mounts as the rb30 bottom i think is 38mm bigger. I am also sure rb25 pistons will fit but may not be the best option you should go with, forged pistons will definently be the best option.
Aftermarket ECU is a must have and with a dyno tune you should be set mate.
this is exactly what im going to be doing, but i will be smacking GT35R on the side of mine :(
The neo head has slightly smaller combustion chambers than the normal rb25/26 head, its somewhere around the 60cc per pot compared to 64ish cc in the normal head. This makes quite a bit of difference to the CR.
With the na rb30 pistons, a deck block, thin hg and the neo head, that would have to net around the 10:1 if not higher. I think the na rb25 pistons might be a tad too much but just grab one of the online CR calculators and start plugging in numbers and you'll see what you'll need. I havent really looked that much into the na side of things since will be going the turbo route, but with mine acl rb30et pistons, neo head, decked block and a 1mm hg will get around the 8.5-9.0 CR mark. Obviously with the na route you would want much more than that
if you are using the neo head and want a high compression turbo motor (RB30DET), grab the flat top CP pistons that spool sell in his kit for the normal rb25/30. Depending how you set up the motor, you'll get anywhere from 9.0 to 10:1 CR, i doubt you'll want more than that
I want mine around the 8.8 mark, still responsive but will still like some boost :)
Im aiming to run everything as standard just with the 30 bottom end and 25 pistons switched. Then a safc will prob do for the extra fuel. Wat machining is required? and do i need a better oil pump than the vL one?
You will need water pump collar and to relocate a pulley.
Google "RB30DET" and .pdf. there is an awsome file out there.
i'm going to take a stab in the dark and assume you meant oil pump collar instead, but thats only if he uses a widenose gtr pump :D
Edited by R34GTFOUR
if its going to be a daily the rb25 pump will do the trick, you wont need the crank collar sine the rb25 runs a narrow nose crank like the rb30
If you are going to spend abit of $$ on the conversion and track it abit, an upgraded oil pump is good insurance
  • 3 years later...
before this goes any further, and before a motor blows up
a neo head has a smaller chamber, ive measured them between 52 & 55ccs
in the tech section there is a simple maths formular i wrote up to work out your actual compression ratio, guessing = problem waiting to happen
flat tops with neo head estimated around 9:1 static
  • 1 month later...
So as OP posted what kind of compression it will reach Neo head and 30 block, couldn't find the answer and really bad in calculating compression I am looking around 11 for my NA setup
    • No, I don't remember the exact reasoning (was 20 years ago!) but the cops didn't end up supplying it to us either. Actually my mother went through a similar thing recently where she was hit when stationary, flustered and didn't get address (she got plate details, name, phone and insurance company, but not address). Person who hit her blocked her number and their insurance company (naturally) would not provide any details. Her insurance company also required her to pay the at fault premium because she did not have the address, cops did not help as it is a minor civil matter (they said their only course was if the other driver had left the scene of the accident without providing any details). She only ended up getting that refunded because they happened to be insured with Suncorp and she was with APIA so same company owners. For some reason the address is critical in insurance companies recovering money from the at fault party
    • If you're driving something like an R32 through to R34, no chance of meeting Euro4. Euro4 came out in 2006, and car manufacturers back then were complaining how hard it would be to meet those regulations. Not a chance a vehicle 10 years earlier is going to be compliant.
    • I presume it would take more than just slapping a big modern catalyst on the exhaust? It's interesting though, looking at the old sales brochures and listings it does not mention anything about emissions. No one cared.
    • Yeh nice, looks like their part of keep it reet? Will have to swing past. I'd much prefer someone actually look at my car and custom make a part, then get a generic part online and hope it works.
    • No, but they will be WAAAAAAY too high. You will never get your ticket.
