I ended up changing a friends clutch in an r32 gtst over last thursday and friday arvo. Now the job in itself is straight forward except for 1 or 2 bastard bolts, but going to the effort of doing it on the floor in a car port to save a few hundreds bucks may not be worth it. The box weighs a friggin tonn. All i can say is if you have to take your r32 box out think twice because you could have yourself some very sore arms the next morning and you will have done a hell of alot of swearing while doing it.
https://www.sau.com.au/forums/topic/25348-replaced-r32-clutch/
if u think the gtst box is hard and heavy try doing one on the r33 gtr then u'll swear a bit more . on the gtr to get to the top belhousing bolts u have to lower the engine box assembly first .the box is much longer than gtst and it weighs 90 kg but u can still do it on the floor with a trolley jack .
ive still got 2 bolts missing from the top of my g/box with no ill effects and its been like this for 4 months now of constant driving
i will need to get these put back in tho at a later date :)
btw is it the daiken excedy organic clutch? if so this clutch is great - ive found no problems with it at all and its great for everyday
kamikazer33 the top g/box bolts on the r33 gtst are doable even without droping the box . its only the gtr that u cant do unless u drop the box a bit . anyway i would do them as soon as possible u may snap other bolts as u have more load on them .
    • Nah, you failed to pay your washer cover subscription and BMW have revoked your access.
    • Haha thanks Lith,  So it's currently working quite well and the torque reduction is setup and working phenomenal. It also got a custom torque convertor from All Fast in WA. Stall speed somewhere around 5500rpm unlocked but still with the lockup. The car went back onto the dyno after a 3yr hiatus (even with the dbw, and other mods completed in this time) managed to make ~515kw at all 4 hubs. Sean setup the Torque reduction which now sounds awesome and working well. We setup adjustable torque controlled launch control aswell.  Man what a feature. Especially when drag racing on street tyres I Managed to get out to the drags late last year and tick a huge bucket list item off of running mine and the cars first 9. Car went a 9.98 @142 Still had the young fellas car seat in the back aswell.  This was on 255/40/17 Nankang AR-1.  Currently the Turbolamik is still completing it's own torque calcs and managing shift times from there. Unfortunately emtrons can export is still a little restrictive to export the ecu calculated torque just yet but I have recently been suggested a work around that I just haven't had a chance to trial yet.
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
