For sale here is an excellent, quality 5 speed manual R34 GT-T Skyline. It has been very well looked after with regular services (3000 - 5000 K's) using quality oils. The car runs extremely well, and my mechanic says it is one of the cleanest Skylines they have ever seen (Dynamic Mechanix, Rockhampton, Ph. 07 49272112).
Why pay $20000 for an R34 with little mods when you can save thousands by buying an already modified car that is in better condition than most you will see.
My modifications include;
- Hi-Flowed turbo by GCG still under warranty
- Blitz front mount intercooler (mounted properly with a sports radiator fan so the cops will leave you alone)
- Blitz turbo back exhaust
- Nismo oil cooler
- APEXi Power FC
- Blitz ID3 electronic boost controller
- Blitz turbo timer
- Black mags with Bridgestone Potenza Adrenaline RE001 tyres for awesome grip, still with most of their tread
- Turbosmart blow off valve
- Bilstein coil-overs
- New brake pads and spark plugs
- Dark window tint
- Clarion CD head unit
- Inverter in the boot so you can hook up a tv and dvd (I have both and I will include them in the sale if you like)
This car recently received QLD Transport approval so it is a hassle free car, the cops will leave you alone.
Anyone who has seen me driving this car around knows that it has not been thrashed, and that it is well cared for.
I will be sad to see it go, but am purchasing a house so it's time to downgrade.
I live in Emerald but can easily drive to Rockhampton, Mackay, Brisbane etc. for any genuine buyers.
Please feel free to call me with any questions.
Matt, 0419668773
Thanks mate, it's a nice car isn't it.
I have had a lot of interest and have had people try to finance the purchase of this car but unfortunately were turned down. I don't think it will last long at this price and in such good condition so get in quick.
Due to my remote location I am happy to take the costs of flight to Rockhampton to view the car off the purchase price (up to $500) if you buy it. If you want to fly up to see the car I can meet you in Rockhampton, but I will only take the flight costs off the price of the car if you buy it. If you don't buy it then you will have to pay for the flights.
I just thought this would help serious buyers get a good look at the car and what great value it is.
Virgin and Jetstar always have cheap flights to Rocky, from as little as $39 from Brisbane.
It made 250hp at the rears with stock injectors and fuel pump. Was starting to run lean. With bigger injectors and fuel pump and higher boost you will make a lot more power. The hi-flowed turbo is rated to 450hp.
Offers!!!
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
