For sale (rims only, no tyres):
Set of 4 brand new 18 x 8 inch PRG rims in their individual boxes (see attached pics). Never had tyres fitted.
PCD: 114.3 x 5
Offset: +38
Please ensure that these will fit your application, particualrly the offset.
Price $800 firm. Pickup only.
Contact number: (03) 8614 4970
Edited by Big Zil
Also have 4 Fullrun tyres with minimum 80% tread on them.
I went wider on my car some time ago so these have to go.
Specs are:
Make: Fullrun HP199
Price: $200 firm. These were $150 each new.
Price Drop on the rims : $750. They are brand new in the boxes.
Mobile contact: 0403 063 178
Edited by Big Zil
Update for those interested in these rims.
Please note that if you are running big brakes e.g. Brembos that these rims will not clear the calipers. I had a Mitsubishi Evo 9 owner come out only to find this exact problem even though the Evo runs a 8 inch wide rim with +38 offset from the factory. The problem is due to the lower brake caliper clearance (X-factor) spoke design.
So if you're running a similar offset to these and have a big brake setup, do not bother enquiring about these rims.
Hi guys
I am the evo 9 owner that tried these rims on for size which did not fit.
I must say the rims are great fantastic buy if you ask me they were perfect looked even better in life.
If you have a 5x 114.3 stud pattern dont miss out on these rims.
Cheers
Price drop on 'Wheels and tyres' but must be as a package.
$800 no further offers (this is cheap!)
If you want to only purchase one or the other the price is:
$750 for the rims.
$150 for the tyres.
  • 3 weeks later...
  • 1 month later...
Stud pattern suits both cars.
Don't know what offset the NA R34 runs.
As for the Supra I think it runs 16 x 8 inch up front and 16 x 9 inch on the rear both around +50 offset (but you'll have to check).
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
