i see
anyone here sustained damage from this ?
All the banging will hurt the oil pump
Without one its easy enough to kill a oil pump if you hit the limiter hard, often etc... so with one of these bang bang devices, it can only be worse
fitted one of these....2nd launch smashed my oil pump.
it depends on how far back you go with your timing retard doesnt it? if you're going for a -3 or a -5 timing retard then it shouldnt be too bad. anything over than then it gets too aggressive.
Paul, what timing retard did you have?
Can anyone elaborate on why it would be bad for oil pumps?
Basically what your saying is my Power FC Pro is worse than a standard Power FC on the limiter?
I thought the whole idea behind ignition cut was it was easier on the motor?
just like key bangers for non injected cars... drive along at say 60km, switch off ignition and pump accelerator pedal vigourisly, then flick the ignition on again and shazam - a nice big BANG from the excess fuel.
sounds great, but I blew the exhaust off a friends corona years ago when we used to do this for a bit of fun :) wouldn't put one on my GTR...
  • 4 months later...
if you bought the car like that then i'd say its seen some fairly high revs already :)
try to get a real ecu
I bought it 4 years ago, dead stock, mint condition. I put the chip in.
Everyone else,
I found the problem, an aftermarket dump pipe I had installed had a bolt hole in it for a different kind of turbo that hadn't been closed up. The car was running rich due to the leak being before the 02 sensor, which made the bee*r much louder.
It's a lot better on the 1st setting now, doesn't sound like it's gonna blow up, as well as the car being faster with a better fuel tune.
i love these limiters... but i like my engine more... its basically the same sorta thing as antilag but different.. haha. engines/turbos hate antilag
i would think that setting 1 would be loud as i think its the longest delay so more fuel would be pumped into it and a bigger bang. the higher the setting, the shorter the cut, the more frequent but less violent bangs.
U got it backwards mate...
i tried key bangers in my corona heaps with no success
im actually glad the topic on oil pumps had been brought up, i was wondering if a lower limit like say 4-5k like u would set with a bee R for the wank factor would be as damaging as a say 7k limit for when u actually run out of revs. it appears the answer is yes
they say its safer because its still putting fuel into the cylinder so its not like detonation, its also why it goes bang because of the fuel getting ignited, i love these things
def the opposite i've lost count of the dead engines (mostly RB and CA) caused by the direct use/misuse of a BEE-R limiter, i have never installed them and never will.
as for the guy who started this thread, put the std limiter back in use and sell the BEE-r to some squid on ebay.
  • 3 weeks later...
Thanks for all the replies and info everyone!
After having the bee*r for 6 months I think I have only hit it while driving a few times (apart from intentionally revving it to scare people a few times when I first got it - the novelty of which has worn off, especially due to the stories of dead engines, oil pumps and whatever else!)
I figure if I rarely hit it (It's a just-in-case deal now, so I don't accidentally do like 9000rpm and kill my engine) I should be safe... does that sound right to you guys? I have it set to 7500rpm which is pretty near the end of the power band so it's not excessively easy to 'accidentally' hit it...
My other option is to reinstate the factory limiter as URAS suggested... the factory chip had one but this new chip doesn't - does anybody know if there is an easy way to 'program' the rev limiter back in? I have a consult cable if that helps...
Thanks again!!
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
