Hey, i bought a few GTR boxes (push) and some sr boxes, thanks to the importers they gave me a heap od forks and carriers that "should fit" haha, its ok as they were cheap. Anyway, does anyone have heights of the GTR carriers so i can identify the right one, or can i use anyone with the correct height bearing? I'm converting my GTR from an extreme twin plate pull clutch to a push gearbox with a nice sprung center Blitz clutch, does anyone know the dimensions of the bearing i am meant to use with this?
Thank you
cool. well 99.9% of multi plate clutches all use the 12-14mm carrier. mesured from the base of where the bearing sits on it to the surface the fork rubs on :)
no idea what car they come from..
ps.. you must use the small "datsun" bearing. (the standard one is wrong for a multiplate., a very common mistake)
they go right up to 25mm or so for the stock clutches.
thank you, i have found on the ORC site a PDF with all the nissan numbers with there respective measurements! Also i went to a reputable clutch place here and bought a small throw out bearing as you described its very thin. I just ordered a new push slave cylinder to suit the new g box and ill dummy it up and take some measurements and see where im at, but it looks good to go atm.
Thanks
yo
just having a read threw here.
about to put my 30det and 25t box together with a nismo twin plate clutch.
measured up my throw out bearing carrier and mine is more like 22mm???
and im unsure if its the factory throw out bearing.
it came with the clutch kit that was brought brand new from a private seller..
how do you go about getting the smaller throw out bearing carrier and such
cheers tom
well it all depends, what i did was use a 16mm carrier with a 16 mm bearing (small usually like 22ish) then it was a little bit too small, so i spaced the pivot ball out 2mm. You can change pivot ball spacing, bearing and carrier.
goto nengun, they have the ORC bearings and a link to the ORC web site, on the last or 2nd to last page of the catalogue it has all nissan part numbers for the carriers. I just ordered a brand new nissan 14mm carrier and dont need it so if u want it i will sell to u for what ever it cost me (they week wait special order from japan)
the ball, short is a 14mm bar with a ball on it. the lon one is just longer. like 30mm or so. make sure you use locktite on the ball as it will leak oil if you dont.
of and the bearing is heaps smaller in diameter ie: the rubbing surfave is just bigger than the sleeve its pressed onto. where the stock one is alot bigger.
nismo use the small one.. youd be supprised how many people sell there twin plates because its to hard to drive....all because they have wrong bearing. nismo also needs a 16mm~ carrier. i used a 12mm one with my g-max3.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
