Hey,
When i had my standard rb20 turbo with full exhaust and intercooler, the only boost control i had was the factory rb20 actuator.
With this setup it would leak/spike to about 13psi (from the factory 10psi setting)
This was most likely due to the larger exhaust flow making it creep up to 13psi.
Even using a manual bleed valve, it wasnt able to go below 13psi...
After i put in a hks2530 with the same rb20 actuator, it spikes now to 15psi...
Is there any reason why it isnt holding itself at 10psi?
Plenty of r33 owners put on rb20 actuators on their car's and hold 10psi..mine seem to be all over the place haha.
Im pretty sure the wastegate flap was checked to see if its not getting caught on the dump pipe (as it is a split style)
So yeah, is it normal for it to spike to 15psi on standard actuator? Car will eventually be tuned to 17-18psi using a manual bleed valve.
Thanks
https://www.sau.com.au/forums/topic/253541-rb20-actuator-spiking-to-16psi/
A bleed valve is going to make it higher.. its bleeding air so the actuator doesnt get the "10psi" doesnt it? So that wont help
Maybe the actuator rod isnt long enough on the HKS turbo? So its only opening half way or not quote fully?
I thought the HKS turbos had their own actuator?
Like these ones
EDIT: i just re-read it. You have the split dump.
I had that too, and with the RB20 actuator on my RB25 it would creep to 14-15psi.
I know for sure it wasnt catching either as i had it modded so it wouldnt.
It sucks, but put a stock dump pipe on and try it. As soon as i put my OEM dump pipe + HKS front on it dropped to a perfect 10psi all day every day.
SAU will love this! This is my theory...
What you think?
Edited by gotRICE?
haha nice drawing.
The HKS2530 was purchased 2nd hand without a hks actuator. The turbo was since then rebuilt and my old rb20 actuator used.
I am using a stainless steel Bos-Importing split front/dump pipe (batmbl)
Thanks
haha nice drawing.
Thanks
In that case, ignore my n00bness ;)
But in saying that, i find the best way to figure shit out is buy going backwards if you know what i mean. You add something and get a problem, try eliminate it easily, failing, then maybe try replacing some stock parts you know?
dont know anything about those dumps are they quality or chinese crap?
They very good quality dumps, SAU has had several groupbuy threads and they cost around $400 mark
http://www.skylinesaustralia.com/forums/Ba...l&hl=batmbl
Does anyone have a split front/dump pipe with an aftermarket turbo? Any problems with spiking with standard actuator. It must be either the dump or the actuator causing it because it would spike to 13psi on my factory turbo..
Cheers for help
I would hardly call 13psi spiking first and foremost...
What other mods do you have on the car...any form of intake or exhaust mods like a cooler or 3" exhaust and it will run more that 10psi...let alone with an aftermarket turbo that flows more...
And fyi even with a bleed valve you can't lower boost...only raise it...and with a bleed valve you will still experience a little of this so called "spiking" even if it was running right as its a manual system and it takes time to react and come to a steady state...
Also...check your wastegate flap AGAIN because although it might be opening it might not be opening fully...you said you're pretty sure...unless you did it yourself...never be sure...the flaps on HKS 25xx turbos have been known to foul on the split dumps...
AND FINALLY...hks turbos are more efficient around 1-1.2 bar anyway...so harden up....
it was hitting 13psi on the standard rb20 turbo and did not worry about it. As larger exhaust and intercooler would increase it from 10psi
Once the hks2530 went on its hitting 15psi and some cases 16psi on a standard rb20 actuator (with no boost control devices).
Just wanted to clarify if its normal for the standard 10psi actuator to allow up to 16psi..
i think its quiet find for standard actuator
im running 18psi with high flow turbo and standard R33 actuator with a AM performance split dump i noticed when i went to a full AM performance exhaust i picked up about 4-5 psi because the exhaust was more free flowing
i run a EBC now and hit 1.3 bar constantly
Mine does the same but the only difference is i got the gt2535. Learn to live with it lol. I've changed dumps (screamer/ bellmouth) r33 acuator (went to about 10psi but laggy as hell), hose's, taken out boost controller and still. Just smash 20psi into and enjoy it :)
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
