Ok guys, got a sweet RB25 gearbox with short shifter installed. All the selector sh1t was replaced upon install of the shifter. No pics.
$1400
Also have a full set of Tanabe Sustec Pro R33 coilovers. Had a good look at them and they seem pretty mint. HKS tops on the rears.
$750
R33 Stock Viscous LSD. Shim it up and change the rear casing at the same time for all you 5 bolt obsessed S13 kids.
$300
R33 Fujitsubo exhaust. Twin pipe design. by the look of the design this flows awesome and isnt overly loud.
$350
R33 interior (blue and grey velour). All seats and plastic bits. no door trims available but i spose they can be sourced elsewhere if needed. great cond. no rips or tears, will shampoo to
$400
If anyone makes stupid offers I simply wont acknowledge you.
Many thanks
Christian
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
