Hey people as the topic says i'm chasing the bit that goes around the steering column that has the indicator, g-senor, bit that makes the horn work and so on. It looks like my car has come from japan with some of the inner bits removed and the bit that makes the horn work is totaly gone which i need (police dont like non working horns)
Also chasing the under dash trim with the factory clock in it the goes underneath the steering column bits
Cheers, mat.
https://www.sau.com.au/forums/topic/253608-r32-parts/
Cheers, mat.
I have the indicator etc steering column bit that you're after but not heard of a factory clock under the column bits...? It's usually built into the dash cluster.. Yours turbs and/or hicas?
What would you be wanting to pay for the indicator bits? I'm in Adelaide and will gladly post. It would only cost about $5 - $10 max... Let me know either way ;)
Edit: Just noticed you have a GTR and this is off a GTST so may not fit...
Edited by partyboy73
https://www.sau.com.au/forums/topic/253608-r32-parts/#findComment-4383133
Nah she wont fit mate, it has the g-sensor inside that operates the hicas and split torque for the gt-r.. but thanks anyway.
Bump, surely someone must have some spares from a half cut?
https://www.sau.com.au/forums/topic/253608-r32-parts/#findComment-4384705
the g sensor that controls the torque split is under the centre console... if its this you need i have one ....im sorta wrecking a r32 gtr...
Oh ok, i'm mainly just after the bit that contorls the horn and indicators.. so pretty much everything inside the plastic behind the steering wheel boss..
https://www.sau.com.au/forums/topic/253608-r32-parts/#findComment-4387888
  • 4 weeks later...
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
