Has Any1 Been Pulled Over By A Vicroads Van?
Something another forum member brought up reminded me.
I see quite a few of these VICROADS vans on the way to work. Usually I believe they check out trucks, so I never paid them any attention, but has anyone been pulled over and inspected by one of these things? Does anyone apart from the cops have the right to?
Thanks.
i was under the intention that the vicroads cars can pull u up but focus more on the trucks/heavy vehicles
and the police focus mainly on cars
but still can pull you up if they wanted to, its vicroads they are the ones that have all the rules for the legalities on anything on the road in victoria so im guessing yeh they could and it would be a lot worse than the police pulling you up
You might find them however when they do the big defect stations.
Where the have everyone from Police, EPA, VicRoads to the VTD and immigration people checking taxi's (which i found to be amusing at the time)
I've seen it on Dandy Rd before near caufield... massive operation.
Although who was looking @ what, i dont know.
AFAIK.... You are not required to pull over for anyone till you are sure, and believe it to be safe (or something along those lines). So interpret that as you will. ;)
I once made a cop drive for 1.5k with lights and sirens on, to my house before i 'pulled over' in my drive way.... before he could read me his right act. ;)
Oh and i'm working where they turn normal Chooktins and Commondoors into Police cars ATM (i saw the Girl's Blouse H3's getting their lights and stickers get put on).... and they have a few VW transporter vans and utes in the "to do queue". Along with countless other cars that aren't designed to turn corners. :D
I'll try and get some sneaky pics tomorrow. :)
pretty sure the vans are just for accidents cause they have all the warning signs and that on them
the vicroads vans are for citylink when there is a breakdown or accidents...
the vicroads cars pullova trucks as they are sumtimes a hazard to safety....but when the pull u ova they look over everything and i mean everthing and there fines are huge.....so iv heard
cheers moe
cheers moe
VicRoads vans are not for breakdowns on citylink...
Citylink has their own vans for breakdowns and so on. Its covered by the tolls you pay id imagine
got tail gated by vic roads Dandy one time, was thinking to my self EPA for exhuast,
but the van in front of me was pouring out black smoke, vic roads sped up got infront of me purple lights on for the van.
worked with a guy who thought it would be a good idea to take his ICE decked out wagon to industrial area and pump music and skate around the area.
security doing his shifts told them to stop and leave, they just gave him cheek, he asked them two more times, and they got angry and vocaly abused him.
security guy called Vic roads and explained, they came down with tool's issued them a 'sound polution notice' and took out his head unit ....party over
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
