Oil In Water
Kasmick
 Share
Hi Guys,
Got a bit of a problem which i require help with, i am getting oil into the water system and radiator but it is not the head gasket. I know this because i changed the head gasket but saying that there was nothing wrong with the old one anyway when i took the head off.
Now it is a R32 GTR and it still drives completely fine, there is no water in the enigine (oil) at all and i have been driving it around for a bout two weeks now, although i am slowly, very slowly losing oil from the engine.
So obvioulsy the oil is some how leaking into the water system, now i have a couple of ideas which i would like some help on.
Is it possible that the oil could mix into the water through the turbo?? a seal broken or something??
The other option is the water/oil trasfer thing that the oil filter bolts too??? Is it possible for this to leak oil into the water??
Any help would be great guys.
Thanks
Hi Guys,
Thanks
maybe a cracked head?
Hey mate, see where your oil filter is screwed onto? there is a metal disc plate just off to the side which has a bolt going straight through it. that is your factory stock oil cooler. over time they can rust out as the core inside is fairly thin or the core inside separates and your oil will mix in with the water. i had the same problem when i had my 32 gtr. its an absolute c*nt trying to reach it but i did it from underneath the car. if you have skinny arms you should be right. change that cooler or fit an aftermarket cooler and it shoudl fix the problem. worked with me. i ended up blowing my head gasket two weeks later anyways. Doh. haha.
and also if you do decide to fix it buy a new oring kit for it. if i remember it came with three o rings. two little black ones and an orange one. this kind of problem happens on old cat loaders and various trucks ive worked on. they run a similar setup too.
Hey kasmick,
Sorry to be the bearer of bad news but it definitely sounds like you have a cracked head,
the reason your not getting water in the oil is that the gallery thats cracked in the head is the oil pressure side so
oil pressure is higher than water pressure therefore the oil goes into the water,forget head gasket,heat exchanger etc.
If you like by-pass the heat exchanger to check again but i`ve experienced this many times.Theres a company here in the uk that does repaired heads,although the shipping/labour costs for shimming etc maybe too expensive.
 Share
    • I'll snap up some photos when I'm back home, in the office today meeting my "in the office" quota. Have 2x Teams calls scheduled in, office culture they reckon.   I've never owned a proper off the shelf sub, I've always made or modified broken ones with Jaycar plate amps and/or car subwoofer drivers. The current (and broken) subwoofer has a proper home driver in it, Dayton driver, thos one https://www.daytonaudio.com/product/118/rss265hf-4-10-reference-hf-subwoofer-4-ohm FS of 25Hz, which is low but not low enough. Yeah, I think they were brought out to the market to compete with SVS. I would love a SVS PB-3000 but they're not cheap, especially after their price hike. From reviews online, it does look like the Tonewinner D6000 would destroy and with good amount of money saved too.
    • yeah, that happens too.  I'm really enjoying 4WDing at the moment, seen a few beautiful spots and want to go explore more of this enormous country.  The 370Z got a clutch LSD in it and a track day, great fun.  Getting the back end sorted out really rejuvenated my enthusiasm for driving it hard, the viscous one is poo especially in such a short and wide chassis.  The VLSD unpredictability was more benign in a long and skinny Skyline.
    • With my pre/power I use a remote trigger cable(3.5mm jack each end). I turn tv on, it turns both on via ARC. Or, just the pre with the remote or its streaming software, turns on both. Not that difficult at all. Obviously,  you would also want to actually update/upgrade over other factors in your life(bills, family, other hobbies, etc)
    • Yeah, nightfall was very "meh". And I'm crap at pvp, so feels like everyone has cheats(it's just my lack of skill). Final shape has been pretty good. New raid and dungeon are pretty good. If you want to give it a go, probably wait until it's on sale. But, as usual, most of it feels very familiar.
    • This morning was Kingswood's Microscopic Wars. It is the album's 10 year anniversary this year and we went to see them play the whole album as a special show a couple of months back. Was pretty spectacular.
