LIST UPDATED
R33 40mm triple core JJR radiator $260 ($375 new)
Stock R33 GTST fuel rail and stock injectors $160
Stock R33 GTST plenum and throttle body $160
R33 GTST complete air con unit underneath dashboard $160
R33 GTST wiring loom $200
Rochester 1000cc 14mm fuel injectors for RB26 $560 (used) (Retail @ $120 each)
Whiteline Front & Rear adjustable swaybars for R33 GTST $340 for the pair
Stock R33 GTST airbox/snorkle with Apexi panel filter $60
Stock R33 GTST intake/BOV piping $100
Hawk brake pads for R33 GTST (New) Front $110 Rear $100
R33 GTST air conditioning compressor $150
R33 GTST air conditioning condensor $50
R33 GTST air conditioning hoses and brackets $50
R33 GTST climate control unit $40
R33 GTR intake plenum freshly powdercoated (intake is slightly squashed) $200
GTR HKS BOV (old school style) $60
R32 GTR stock coilpacks $60 (1 clasp has broken, visible in pic)
R33 GTST stock coilpacks $80
R33 GTST rear window $200
R33 HICAS unit $50
R32 GTR stock front pipes $20
R33 GTSt front & rear stock sway bars $100 (pair)
  • 1 year later...
  • 1 month later...
Hi all,
I have for sale the following items, I am located in Sydney and am happy to post at buyers expense :P
Apexi pod filter for R33 GTST $40
Stock R33 GTST turbo (1 exhaust stud has snapped) $300
Stock R33 GTST intercooler & piping $50
R33 GTST turbo lines $60
R33 GTST climate control units x 2 $40
R33 GTST split front/dump pipe in stainless steel $260
R33 GTST stock boost solenoid $30
R33 GTR intake piping (yellow) $60
R32 GTR stock coilpack $60 (1 clasp has broken, visible in pic)
R33 rear wiper $60 (rear window to suit $200)
R33 HICAS unit $50
R33 GTSt stock turbo back exhaust $60
Hi mate keen on the airbox. My number is 0403 963027. Where are is the item located? Cheer james
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
