Hey,
I noticed a decent amount of people here say they have an amp in the boot right next to the battery. I just looked at mine then since i have an amp and i realised that theres wires next to the battery and the metal bit isn't exact straight either, it slopes down. So i'm assuming those that put the amp in their boot next to the battery added something to go over the top of the wires for the amp to sit on.
Could anyone tell me how they put their amp next to the battery and provide pictures if possible?
Thanks.
https://www.sau.com.au/forums/topic/253636-putting-an-amp-in-the-boot/
No pictures here... but I just got some aluminium angle from Bunnings and made up a bracket which used the screws from the fuel-pump cover.
Currently got an amp, PC power supply and USB soundcard in there... soon to put another amp in as well ;)
i mounted my amp so that when you open the boot.. its staring you right in the face. i got a piece of mdf and screwed it onto the 'back wall' just under the strut brace, then stuck the carpet bit on and the amp over that. looks ok i guess.. haven't hidden the wires perfectly but you could if you wanted to.
very nice job mintr33! very professionally done! i like it!
But hey Tyson1990 if you want something real simple just get a thick piece of mdf board and cut to size. you can screw 1 side into the battery tray and the other side into the metal which will bring it up so its not on a lean. this will also hide the existing wires and give you some space to run your own as well.
the picture included is not of an amp install, originally i had an amp here but now they are all on show so i've used this space for fuses and stuff. but gives you an idea of the board used which will do if it wont be seen. mintr33's is awesome, but looks like his is fabricated specially to suit with brackets to size and everything, a lot more work involved but looks the part, so really depends on what lengths you want to go to.
hope this helps.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
