Hey,
I noticed a decent amount of people here say they have an amp in the boot right next to the battery. I just looked at mine then since i have an amp and i realised that theres wires next to the battery and the metal bit isn't exact straight either, it slopes down. So i'm assuming those that put the amp in their boot next to the battery added something to go over the top of the wires for the amp to sit on.
Could anyone tell me how they put their amp next to the battery and provide pictures if possible?
Thanks.
https://www.sau.com.au/forums/topic/253636-putting-an-amp-in-the-boot/
No pictures here... but I just got some aluminium angle from Bunnings and made up a bracket which used the screws from the fuel-pump cover.
Currently got an amp, PC power supply and USB soundcard in there... soon to put another amp in as well ;)
i mounted my amp so that when you open the boot.. its staring you right in the face. i got a piece of mdf and screwed it onto the 'back wall' just under the strut brace, then stuck the carpet bit on and the amp over that. looks ok i guess.. haven't hidden the wires perfectly but you could if you wanted to.
very nice job mintr33! very professionally done! i like it!
But hey Tyson1990 if you want something real simple just get a thick piece of mdf board and cut to size. you can screw 1 side into the battery tray and the other side into the metal which will bring it up so its not on a lean. this will also hide the existing wires and give you some space to run your own as well.
the picture included is not of an amp install, originally i had an amp here but now they are all on show so i've used this space for fuses and stuff. but gives you an idea of the board used which will do if it wont be seen. mintr33's is awesome, but looks like his is fabricated specially to suit with brackets to size and everything, a lot more work involved but looks the part, so really depends on what lengths you want to go to.
hope this helps.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
