As for the 2 door commodore, LOL, yeah i drive a gtst, it owes me 16k and i only have 211rwkw, you have a 2 door commodore that owes you 40k+, so once i spend another 24k+ i wonder how small you will be in my mirrors,
I didnt say anything about u owning a gtst some one else did so read the name before then posting attacking a monaro that u cant afford.
  • Replies 63
Posted Images
That was not aimed at you, R31nismoid must have deleted the post that it was aimed at which WAS the one before it, was posted by some one with the name of BRAAAA or something like that, he made a remark about me only having a gtst.
And for the record, no i cant afford a monaro, but before i bought a nissan i was a ford man, still am now and will be for the rest of my life, therefore have no interest in a monaro, an F6 typhoon on the other hand......
Edited by W0rp3D
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
