Deca Accommodation - Fri 27 / Sat 28 February
Bec
 Share
OK have booked us about 20 rooms in Shepp for the upcoming DECA.
When: Fri 27 and Sat 28 February
Where: Tirana Motor Inn
Address: 33 -37 Wyndham St, Shepparton
Website: (if you wanna have a look) http://www.tiranamotorinn.websyte.com.au/
Cost: $50 per person per night
If you would like a room, please let me know as soon as possible.
I need to know:
* nights staying
* how many people
* what bed configurations you need (ie twin, double etc)
If you are coming by yourself, just let me know and I will team you up with somebody else to share a room with.
Dinner is booked at 7pm at the old Taco Baz establishment - now called Not Just Mexican (yes im told they still have margharitas in big glasses!!!)
Let me know here, by email, by PM or by phone.
The sooner you tell me, the easier you make it for me.
Cheers
  • Replies 42
Oh Bec you know im in :D
Ill get onto this right now for you
If that's the case i want to see the R this time :)
Bec, i'll take the double+3 singles room - 2 nights
Thanks
Alan
Hey Bec,
Sorry to be a pain but since they are charging per person, I'll just grab a room with two double beds.
:P
Al
There are no rooms with 2 doubles - sorry.
Have left you in the room with a queen and 3 singles for now.
Are all the Deca spots filled? I've missed out on the previous ones and would love to come to this one...
deca for Feb hasnt been released yet.
Bec, definitely interested in a 2 single bed's for friday night or 4 singles once kris/chad are 100% in.
cheers
Guest
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
