  • Replies 89
-7s/-9s are 330rwkw or so.
-5's are 380rwkw or so...
You need to decide on that, and dont get HKS, they are not worth the price these days now exhange rates are up the creek, go with garrett
7k for the motot build & in/out limits you but then some of the parts aren't bad by any means.
Going off your original as per here:
Ok heres the parts list
-New Crank
-CP forged pistons
-Eagle Conrods
-Gates racing timing belt
-Tomei sump baffle kit
-Mines rocker cover baffle set
-Genuine Gasket set
-Tomei metal gasket set
- ACL Race Bearings to mains and Rods
You can cut out the sump/rocker baffles and the rods (stock is more than fine) if you need to save pennies as i think you wont get all of them in a 7k in/out budget.
You do need however, good ARP rod bolts, they are a key to the build.
Other than that the above will fit, and then 2.5k for the -7s/-9s/-5s and you'll probably end up around 11k-12k fitted and then probably tuning costs on top.
So a bit over the 10k but at least its a decent well equipped setup. Its pretty similar to mine actually except i have GT-SS (got them when the exhange rate was good etc).
u dont need the cam cover baffles, the std ones work fine. Just pull them out and clean out the gausing
the tomei sump baffle looks like this:
which is better than nothing, however its better to get extra capacity aswell as better baffling like this: (this one is setup for an external pickup)
Are you going to be doing lots of track work?
If not, with the right oil mods to the head/block as part of the initial build etc will easily suffice for a street car that might do 1-2 track days/year.
Baffles are not a requirement. Nice to have, yes. But not a neccesity if budget comes into the equation and the second thing to chop out...
with rods being the first place you can save cash if you need.
To give you an idea of the extra prices of my R32 GTR engine rebuild that was finished early 2008 not included in the list of major parts:
Engine balancing & machining - $1250
Head reconditioning - $700
Crank pulley bolt & washer - $20
Crankshaft bush - $18
Key x2 - $5
Oil filter - $15
Idler pulley - $286
Spark plugs x6 (platinum tipped) - $160
Front diff side seal - $15
Engine mount x2 - $170
Shim machining - $10
Rubber plugs x2 - $15
Washers x20 - $50
Gearbox crossmember bushes - $40
Silicon hose - $5
Clamps x4 - $10
Gear lever boot - $18
Coolant x3 - $35
Front diff oil - $30
Power steering oil - $18
Hicas oil - $9
Injector seals & O rings - $40
Motul oil 300V - $118
Motul oil 4100 - $60
New battery - $95
Total: $3192
My total labour bill was over $6000 but I had a lot of new stuff fitted.
Edited by writeoff
Its not cheap to do, you'll find that trying to cut corners will always bite you in the ass.
Doesnt matter how "great/cheap" an option is, there's a reason people dont do it - keep that in mind :P
  Adz2332 said:
Lewis Engines any one used them???
They any good??
There in Adelaide and have quoted me for the whole thing and tuning and they are pretty good!
But do they do good work??
by all accounts they stand by the workmanship. isn't there a few drifters using their engines?
have ot say, they look pretty well setup. I don't think you need a mega dollar build for your goals, just go the 6.5k rebuild, garrett turbos and away you go.
there ar a lot of stock engines making over 300rwkw, so the lewis engine will be good for your goal :P
save yourself some money (you don't need a lot of stuff that has been listed + you ahve a lot of good gear already).
How does this set up sound...? Its slightly cheaper
Deck square to tunnels
Bore and hone
Balance
Acid bath block
Reco head ,complete
Assemble engine from sump to covers
Water pump
Oil restrictor
N1 pump as per customer decision
R33 crank
Forged pistons and rings
H beam rods
Gates belt
Nissan gasket set
Mlsr steel head gasket
Acl race bearings
Remove engine , remove accessories refit engine and fit accessories run in and tune
combine that with a set of Garrett -9s?
ive used lewis quite a few times in the past getting speedway engine's machined up have never had a problem with them with any of the work they have done for me in the past
cheers dean
^ pretty good build above.
However if your just using -9's the added expense of rods really is hard to justify in my book, they will do over 400rwkw as proven many a time over (with good rod bolts etc)
For sure stick N1 oil/water pumps on there
Still no mention of decent rod bolts, only thing you'd make sure of really
yep...the list above is good but forget the rods...totally agree with Ash.
When will people finally get through their heads the stock GTR rods are bloody tough and only in the most extreme engines need to be upgraded (and by upgraded i dont mean to cheap chinese sh1t thats probably on par if not worse than re-sized stockers with a bolt upgrade anyway)
I didn't list them (as I count them as an essential part and was just listing extras) but I used Tomei conrod bolts - $205
Also remember that you will need a dyno tune after so remember to include that in your total cost estimate.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
